Old 01-29-2012, 02:45 PM
hummdeere's Avatar
Member #22776
leaking front hub
I have a 2002 polaris sportsman 4x4. I noticed there was front hub oil leaking down on the inside of tire. I checked front hub and it was empty, not sure where to start or how to do it. Please Help!
Hummdeere
Old 01-29-2012, 03:20 PM
carralo1's Avatar
Member #22352
Probably your hub seal. Go to bikebandit.com and check out a parts diagram of front Hun and you can
See how it all goes
Together
Old 01-29-2012, 05:16 PM
Old 01-29-2012, 06:33 PM
gtxgohan's Avatar
Member #11816
i had a same problem on my 400 check your seal if it looks bad replace it but if it looks good dont buy a new just get some rpv silicon and put it on the area next to the oil seal they say to do it in the book i did this and it was fixed also move the hub around by spinning it that should stop it
2001 Polaris sportsman 400 4x4 olive/ sage green
Old 01-30-2012, 10:08 AM
MyBoyToy's Avatar
Member #19629
does it really work? as I replaced both front seals and they still leak and did you mean RTV or rpv ??? silicon
1996 Sportsman 500--- Old be dependable... starts and runs good, just needs tweaking
ITP 25" XL Mudlites
STI HD2 Matte Black Alloy Wheels
48" Polaris Plow
Old 01-30-2012, 12:33 PM
carralo1's Avatar
Member #22352
Anyone have a problem of it leaking from hub cap? I put a new o ring and siliconed it and still leaking. Unless it's the hub seal and it's running down to the front of the rim and making it look like it's from the hub cap?
Old 01-30-2012, 04:19 PM
gtxgohan's Avatar
Member #11816
rtv yeah it did work it.
i got the Manuel and they say in to do that to gurantee no more leaks
oh and the guy about the hub cap try taking all the parts to the hillard clutch and armature plate and bearings.and put it back together and pull the front axle out all the way sometimes due to it not being pulled out it will leak cuz it will leave open gaps
Old 01-30-2012, 06:31 PM
MyBoyToy's Avatar
Member #19629
Just wondering but what manual? I am sitting thinking how silicon is going to seal a rotating part to a non-rotating part
Do you just squeeze the silicon all around the smooth part of the axle that beds with the seal?
ITP 25" XL Mudlites
48" Polaris Plow
2001 polaris magnum hub fluid
2001 sportsmsn 400 front hub
front inner hub seal polaris magnum 425 4x4
leaking front hub polaris
leaking polaris front hub
oil pouring out of hub cap on polaris atv
polaris 2001 sportsman leaking front hubs
polaris front front hub is leaking
polaris front hub cap o'ring
polaris front hub leaks oil
polaris front hub oil
polaris front wheel hubs leaking
polaris hub leaking
polaris magnum 500 front hub oil
polaris sportsman 500 leaking front hub fluid
polaris sportsman front hub oil seal
polaris sportsman front hub seal
sportsman 500 front hub leaking
sportsman hub seal
what oil do you\ put in front wheel hub of 2001 polaris sportmans 400#gsc.tab
Front suspension leaking air. Makavel07 ATV Brakes & Suspension 3 04-03-2012 04:28 PM
2003 TB leaking front hub??? desertscrambler11 Polaris Trail Boss 1 09-06-2011 07:22 PM
Front Hub still leaking forrest411 ATV Repair and Maintenance 33 08-04-2011 07:32 PM
97 magnum 425 - leaking front hub snkybuster Polaris Magnum 1 07-03-2011 04:45 AM
Leaking from front hub seal 99 sportsman 500 RMR ATV Repair and Maintenance 6 09-28-2010 01:56 PM
