Old 02-01-2012, 08:02 PM
Tomnbon's Avatar
Member #22892
Post serious lack of power
I have a 1998 425 magnum polaris big boss 6x6 that starts easy, and idles fine, but if you give it full throttle, it takes off strong but then just falls on it its face like it's starving for gas. Here's what I've done so far.
Changed fuel filter checked the fuel pump, replaced air filter, and spark plug, cleaned and rebuilt the carb, checked valve clearences, cam lobes, cam chain timing, and ignition coil. I also checked the ignition timing but my service manual was not clear on what the rpm was supposed to be so I checked the timimg marks and made sure the flywheel key was in tact. They were both fine. Could the CDI cause this kind of problem, or have I overlooked the obvious as I often do. Any suggestions would be greatly appriciated.
Old 02-01-2012, 08:12 PM
Old 02-02-2012, 04:55 AM
tt425's Avatar
Member #3687
Welcome to the forum. Have you checked the ETC(electronic throttle control) on the thumb throttle. It needs to be set between 1/16" and 1/8" gap. This is a safety feature and sometimes gets out of adjustment. Some other things to check would be the diaphram in the top of the carb., vacum lines, gas/airbox vent lines, and dirty air filter.
Old 02-02-2012, 01:15 PM
4getful2's Avatar
Member #1234
I agree with tt.
Check carb. diaphragm for cracks, look at the needle while you're in there-center clip position, then look at vent lines on carb. and fuel tank.
Next check broken motor mounts or malfuntioning clutch
99 polaris lack power
99 polaris lacks power
atv falls on its face when you give it gas
loss of power at full throttle atv polaris
loss of power polaris sportsman
lost of power on polaris atv
polaris 425 fals on face
polaris 425 magnum serious loss of power
polaris 425magnum loss of power
polaris 6x6 lacks power
timing chain mark polaris 6x6
2010 xp 550 lack of power rshooch Polaris XP 3 09-05-2011 07:09 PM
99 Sportsman 500 Lack Of Power BNBMOTORSPORTS Polaris Sportsman 9 09-27-2010 03:18 PM
Lack of Power PudJr Polaris Sportsman 3 08-10-2010 02:59 AM
2008 Touring 800 -- Lack of Power CyClones Polaris Sportsman 3 08-08-2010 08:12 PM
magnum 500. lack of power cecdog ATV Repair and Maintenance 4 07-07-2009 11:01 AM
