02-03-2012, 11:48 AM
Member #22939
2004 Sportsman 500 HO Rectifier.
Hello, I have two 04' Sportsman 500 HO that have battery lights flashing. I know they are over charging the battery so first thing I thought was the rectifier is bad. When I called the dealer they informed me that these models don't have a rectifier instead charge through the CDI box. Is this true? I looked in the location stated in other threads and sure enough there is what appears to be a rectifier in front of the radiator. Any help in clearing this issue up would be greatly appreciated.
02-03-2012, 12:17 PM
02-03-2012, 02:17 PM
Member #19204
On my sportsman the voltage regulator is in front of the radiator.
 2008 500 efi, oem front and rear bumpers rear rack 2500lb polaris winch
02-03-2012, 02:20 PM
Member #19204
The regulator was about $120. If you look at, you can see why it costs so much. Theres no aftermarket part that I know of.
02-04-2012, 05:43 PM
Member #22939
Ok, thanks!
04 polaris sportsman regulator, 2004 polaris sportsman 500 voltage regulator, 2004 polaris sportsman regulator rectifier overheating, aftermarket rectifier for sportsman 500, how nto test polaris 500 rectifier, how to check a rectifier on sportsman 500, how to test a polaris sportsman rectifier, polaris rectifier, polaris rectifier smoking, polaris sportsman 500 rectifier what does it do, polaris sportsman 500 rectifier wiring, polaris sportsman 500 voltage regulator, polaris sportsman rectifier, polaris sportsman voltage regulator, regulator polaris sportsman 500, regulator/rectifier 500 ho polaris diagram, sportsman 500 rectifier wiring, sportsman rectifier and voltage regulator, where is rectifier on polaris sportsman 500, where is the rectifier/voltage regulator on the polaris sportsman 500
