Old 02-08-2012, 10:16 AM
sfraser's Avatar
Member #23064
2003 pollaris sportsman 600 reving high
Im a newby. Hi everyone. I bought this used 600 a few years ago and it has 26 or 27 in executioner tires on it for the wife. It always appeared to rev quit high. Now even more. I have a new belt on it as well as a new stock primary clutch spring (blue...from the first owner). Not sure of condition of the driven sheave springs etc. Looks like it was set up for high reving mud. Any ideas on what to do to bring the rpms down to like my 800 without too much cost or maybe something to look at mechanically that could be wrong?
Old 02-08-2012, 03:11 PM
Old 02-09-2012, 02:32 AM
res2cue's Avatar
Member #15153
There should be an "Idle adjustment" screw/knob on the left side of the carb? On my 03 Magnum it is a brass looking knurled knob pointing down. If you do find it before adjusting, get the bike warmed up to temp.
Old 02-09-2012, 04:27 PM
MacD's Avatar
Member #23099
Does it rev high while at idle? or driving? If at idle, x2 on what res2cue said but while driving, im thinking the buttons it the secondary clutch are worn and not letting helix engage properly. Cheap fix [if its the prob], the only hard part is the damn snap ring holding the helix in place. jmo
Old 02-09-2012, 04:32 PM
kcaves's Avatar
Member #10305
Make sure u don't have an air leak as well spray carb cleaner or something like that on the carb boot that bolts to motor and if it revs higher than its cracked
I am here: http://maps.google.com/maps?ll=42.768417,-105.400959
2003 polaris 600 sportsman problems
2003 polaris sportsman 600 no high gear
Sportsman 700 EFI missing at high rev dcorreia Polaris Sportsman 6 02-07-2012 10:21 PM
problem engaging high gear on sportsman 700 2003 julyjosh ATV Repair and Maintenance 2 10-29-2011 07:54 AM
04 Sportsman 600 high idle motonick34 ATV Repair and Maintenance 1 06-20-2011 04:56 PM
2003 sportman cutting out at high revs iride47 ATV Repair and Maintenance 5 04-18-2011 08:16 PM
reving up when should be idling njay1226 ATV Repair and Maintenance 3 03-06-2011 06:15 AM
