Old 02-09-2012, 06:46 PM
alltorain's Avatar
Member #23106
Unhappy Maybe y'all know whats the diagnosis
Been having some issues with my my 1999 polaris sport 400 2 stroke. It started with the spark plug. First I needed a new one. Accidentally was given the wrong one, so I was able to ride for about a day and then it started to give me backfire. So once I had the correct spark plug I was able to ride for a couple to a few hrs for 2 days. On that 2nd day I was doing a little dragging with it and the atv kinda popped a lil bit but not real loud, and it immediately lost power. I cut it off looked it over and then tried to crank it back up. It never cranked back up. The temp. light came on after I cut the atv to the off position and then back on. It eventually went off, and like I mentioned before I tried to start it back up with no luck. If I push the throttle while engaging the push start I get a kinda nasty backfire sound. My neighbor with some car mechanic knowledge is thinking there may have been an underlying problem with a rod or rods that finally showed its ugly face.
Old 02-09-2012, 07:17 PM
Educ8r's Avatar
Member #7168
I honestly don't know a thing about your particular quad but does it have a reed valve between the carb and the cylinder? If so, you might want to check it to see if it is in good condition.
Just a thought.
Old 02-09-2012, 07:36 PM
1999 polaris atv 2 stroke reed problems
whats a full diagnostic on a atv
1991 trail boss 250 4X4. I need a diagnosis!!! 32520 Polaris Trail Boss 46 04-05-2012 08:02 AM
Whats Up Ya All!!! woodycb ATV New Members 5 01-17-2012 05:23 PM
help Diagnosis pblair Polaris Trail Boss 5 11-17-2011 10:54 AM
2003 700 sportsman diagnosis. jimorjd ATV Repair and Maintenance 8 01-31-2011 08:05 PM
whats up? moparfan1234 ATV New Members 2 10-20-2010 10:52 AM
