if you have a new battery, then the next thing to do is to find the start solenoid and jump the two termainals. any piece of metal, like another key will work. turn the ATV key to the on position before you do this. if you manually jump the solenoid and the it still doesnt try to start, then it is probably the starter, and more specifically the brushes inside the stater are probably wore. if it does try to start when you jump the solenoid then you know the solenoid is bad
