Old 03-13-2010, 11:05 PM
lionsmgr's Avatar
Member #3629
2004 ATP 500 HO 4x4/elec. issue
Hello All!
Can anyone help? I have a 04 ATP that won't activate the AWD. The first thing I noticed was the cluster no longer indicated the gear in. Rest of cluster is fine. Also unit would not go into diagnostic mode. Here's the puzzle to me, If I (using a test light) ground out the drum switch/gear position switch I then get the cluster indicator to reflect a gear which thus engages the AWD. With that said, where is my problem? Where would the Drum switch normally get it's ground from and how do i fix?
Thanks all. Look forward to visiting often.
Old 03-14-2010, 04:57 AM
redneck2725's Avatar
Member #3177
Welcome to the site!!
07 Polaris Predator 500
Yoshimura RS3 slip-on
ITP Holeshot HDs
Powermadd handguards
Shockwears shock covers
PRM radiator scoops
Amsoil oil w/ K&N filter
Engine Ice coolant
ODI Rogue Grips
Old 03-14-2010, 05:13 AM
And welcome aboard!
Old 03-14-2010, 08:09 AM
lionsmgr's Avatar
Member #3629
Thanks Guys...any ideas?
Old 03-14-2010, 10:12 PM
cam101311's Avatar
Member #2311
Send a message via Yahoo to cam101311
welcome!
1998 polaris 425 magnum 4x4
super swamper vampire tsl
3 inch lift
500 h.o. carb and airbox
plastic fenders and rack swap
relocated radiator
winch
1995 polaris 400 xplorer 4x4 R.I.P
1998 kawasaki 220 bayou
1998 e-ton 90
Tags
2004, atp, atp 500, drum switch, electrical
1995 xplorer 400 radiator flush
change oil 2004 polaris atp
how to change coolant polaris atp 500
how to change oil 2004 polaris atp
how to flush coolant polaris 2004 atp 500
how to get trouble code for 1995 polaris 500 ho
what dose the diagnostic mode look like on polaris 500 4x4
what kind of coolet for a 2004 predater 500
Carburetor issue dickeys01 ATV General Discussion 14 12-15-2010 07:55 AM
2004 TrailBlazer Rear Brake Issue lpujml1 Polaris Trail Blazer 9 04-26-2010 05:28 PM
2004 sportsman 700 overheating issue midnite_99 Polaris Sportsman 16 04-01-2010 02:58 PM
AWD Issue JustUs2010 ATV Repair and Maintenance 1 01-23-2010 08:51 PM
01 Carb issue Jeff Wright ATV Repair and Maintenance 4 08-20-2009 07:52 AM
