03-26-2010, 01:47 PM
Member #3828
trying to remove clutch to get to starter on 250 trailblazer
i got an 01 trailblazer 250 im trying to put starter in. im not sure if i need to pull clutch from closest in hub or the actual clutch hub, dont want to break it,looks expensive!
03-26-2010, 02:40 PM
Member #1234
i believe you get to the starter from underneath,remove skidplate and remove rope-recoil housing.
03-26-2010, 07:28 PM
03-26-2010, 11:38 PM
Member #2311
welcome to the site!
1998 polaris 425 magnum 4x4
super swamper vampire tsl
3 inch lift
500 h.o. carb and airbox
plastic fenders and rack swap
relocated radiator
winch
1995 polaris 400 xplorer 4x4 R.I.P
1998 kawasaki 220 bayou
1998 e-ton 90
03-27-2010, 05:45 AM
Member #3476
Welcome aboard.
Take care,
03-27-2010, 01:23 PM
Member #3828
yea i c that but it aint comin out without takin off the clutch and cover, no room...
03-27-2010, 02:24 PM
Member #3743
have to take the clutches off and remove the cover
The Kid
heel clicker
Warn 2500 puller outter
SS108's
29.5's Laws skinny/fat
rubber down custom intake
homemade exhaust snorkel
rad. relocated up top
chains on front & rear A arms
swaybar removed
06-01-2010, 06:32 AM
Member #5217
The starter is behind the flywheel, on the right side of the motor, yes, you will need to pull the fly wheel off, you will need a puller, go slow. It's not to bad. be carful not to damage the magnets on the back, or the stater. Exp when re installing the fly wheel. Don't remove the pull starter re coiler, it will unwind.
06-01-2010, 11:14 PM
Member #3805
Welcome you should remove the skid plate to access it and make sure to check the gear before installing it.
06-09-2011, 02:21 PM
Member #15833
2001 trail blazer how does clutch come off looks threaded. also do you have to remove swing arm to pull transmission.
1999 polaris 250 trailblazer starter removal, 2001 polaris 250 trailblazer flywheel removal, how to remove a cluch on 2003 polaris trail blazer, how to remove a polaris trailblazer starter, how to remove clutch on 02 trailblazer polaris, how to remove flywheel on 2003 polaris trailblazer 250, polaris trailblazer 250 clutch puller, polaris trailblazer 250 clutch removal, polaris trailblazer 250 how take off the clutch, polaris trailblazer 250 starter removal, polaris trailblazer clutch removal, polaris trailblazer clutch removal tool, polaris trailblazer starter removal, taking the clutch off a polaris trailblazer, trailblazer 250 clutch removal
