Old 03-31-2010, 05:33 PM
alaskabigbear's Avatar
Member #3997
Hey y'all, I'm new here and need some help putting a project 1996 Sportsman together
I recently purchased a non running 96' Sportsman and have rebuilt the engine and then cleaned the whole thing up. I am putting the the transmission back in but need to know where a few things go.
Can anyone help out?
Working on the side with the sprockets.
Old 03-31-2010, 05:38 PM
redneck2725's Avatar
Member #3177
Welcome to the site!!
07 Polaris Predator 500
Yoshimura RS3 slip-on
ITP Holeshot HDs
Powermadd handguards
Shockwears shock covers
PRM radiator scoops
Amsoil oil w/ K&N filter
Engine Ice coolant
ODI Rogue Grips
Old 03-31-2010, 05:42 PM
Parsons Synthetics's Avatar
Member #3476
Send a message via Skype™ to Parsons Synthetics
Welcome aboard. If I can ever be of assistance, don't hesitate to ask.
Take care,
Old 03-31-2010, 05:44 PM
Member #3997
Can you tell me where things go on the sprocket shaft?
Old 03-31-2010, 06:57 PM
Welcome aboard!
Old 03-31-2010, 08:12 PM
cam101311's Avatar
Member #2311
Send a message via Yahoo to cam101311
welcome to the site!
1998 polaris 425 magnum 4x4
super swamper vampire tsl
3 inch lift
500 h.o. carb and airbox
plastic fenders and rack swap
relocated radiator
winch
1995 polaris 400 xplorer 4x4 R.I.P
1998 kawasaki 220 bayou
1998 e-ton 90
Old 03-31-2010, 08:23 PM
does this help?
1 7515345 BOLT(10) 2 Usage
2 7552901 LOCK WASHER(10) 5 Usage
3 7558402 WASHER STEEL(10) 2 Usage
4 7075339 DECAL,BRAKE SHIELD 1 Usage
5 5241018-067 SHIELD,R.CALIPER,BLK. 1 Usage
6 1910180 CALIPER ASM,R.BRAKE Substituted by 1910224 1 Usage
7 ------- Plate, Bolt Lock (See Pg., Ref.) 1 Usage
8 7552603 WASHER(10) 2 Usage
9 7515522 BOLT(10) 2 Usage
10 ------- Bolt, Shoulder (See Pg., Ref.) 1 Usage
11 7555701 WASHER FLAT(10) 1 Usage
12 7515321 BOLT(10) 1 Usage
13 5431717 GUARD,CHAIN,CTR. 1 Usage
14 7555770 WASHER(10) Substituted by 7558402 1 Usage
15 7552606 WASHER(10) 1 Usage
16 7515346 BOLT(10) 1 Usage
17 ------- Decal - Demand 4 Drive (See Pg., Ref.) 1 Usage
18 7555843 WASHER, FLAT(10) Substituted by 7558302 1 Usage
19 7512269 BOLT(10) 5 Usage
20 7552605 WASHER(10) 2 Usage
21 7074214 DECAL,LUBRICATION 1 Usage
22 5333244 SPACER, CHAIN GUARD 1 Usage
23 3221058 SPKT, 11T 1 Usage
24 7710433 RING,RETAINING(10) 1 Usage
25 1910177 DISC ASM,BRAKE 1 Usage
26 3610026 SEAL, BRAKE 2 Usage
27 7542449 NUT,FLANGE LOCK(10) 2 Usage
28 1590237 BRG.ASM,O/P SHAFT (Incl. 26, NO TAG) 1 Usage
28 7080306 FITTING,LUBE.W/BALL CK.(10) 1 Usage
29 5210764 SPACER,(10) AR Usage
29 5211065 SHIM,.010,GEARCASE AR Usage
29 5211517 SHIM,(.030) AR Usage
30 7515484 BOLT,CARRIAGE(10) 2 Usage
31 7710434 RING,SNAP(10) 1 Usage
32 3221041 SPKT,13T,SPLINED 1 Usage
33 7542403 NUT LOCK(10) 1 Usage
34 7670060 NUT, SPEED(10) 2 Usage
35 7515472 BOLT(10) 1 Usage
36 7542404 NUT(10) 1 Usage
37 7515485 BOLT(10)
Old 04-02-2010, 04:56 PM
Member #3997
Blueline
I actually had what you provided but it is somewhat different from mine. I think I figured it out though. Thanks for the help.
I guess we will see if it works when I get the rest back together this weekend.
Old 04-02-2010, 06:35 PM
good deal!
part #1590237 for polaris xplorer
polaris chain guard 5431717
polaris predator 500 shim diagrams
specs for polaris bolt 10 7515321
1996 sportsman 400 4x4 jet or jet kit djtates125 ATV Performance Modifications 5 10-13-2010 11:01 AM
Putting a winch on trailblazer!? psavas ATV General Discussion 3 04-15-2010 10:23 AM
500 H.O. front lift (level) Project chrisford4x4 Polaris Sportsman 3 11-06-2009 05:38 PM
Polaris project owner indyguy ATV New Members 0 07-25-2009 06:12 PM
Polaris MV7 project for Afghanistan PC Game (request) Wilson_B ATV General Discussion 4 05-07-2009 05:56 PM
