Drive belt issue - Polaris ATV Forum
Old 06-12-2013, 05:40 PM
mtm's Avatar
mtm mtm is offline
Member #36619
Drive belt issue
I replaced the belt on my 03 sportsman 400, i found debris from mice, and now when in gear at idle it still wants to move and with brake applied it will die. Any suggestions?
Old 06-12-2013, 08:54 PM
Old 06-13-2013, 08:58 AM
RVS Performance's Avatar
Member #29606
Sounds like the belt deflection is to tight. Need to shim the secondary clutch open to let the belt ride down a little lower at idle.
Old 06-13-2013, 09:18 AM
MustBeNice's Avatar
Member #29059
Did you blow the clutches out with compressed air to make sure you got all the mouse nest debris out? Maybe some stuck in a clutch restricting it from opening/closing completely or propperly. May need to "carefully" run the machine with clutch cover off and cycle throttle and try blow them out at the same time.
If that doesn't solve it... I'd check clutch allignment or shim secondary clutch open to reduce belt tension as Ridinagain mentioned.
Matthew "MustBeNice"
Mods: Polaris 2500HD Winch - Synthetic Rope - MotoAlliance Line Stopper - Glacier3 60" Plow - Polaris Rack Extenders - Polaris Bumpers - LowPro Shield - Polaris Hand Guards - Warning Debadge - 3Way Head Light (Relay) - Cabelas Mirrors - Wes Ind. Std Seat/Box - Kolpin Fuel Pack Jr - 26" ITP MudLite Tires - HighLifter HD Springs - MotoAlliance Sirius 6" Pro LED Light Bar
Old 06-13-2013, 11:34 AM
bgirard420's Avatar
Member #11494
Drive belt issue
OEM or aftermarket belt? Some of the aftermarket ones are out of spec by just a little and can cause this.
Rather be riding, instead I'm using Tapatalk
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
Old 06-13-2013, 05:12 PM
mtm's Avatar
mtm mtm is offline
Member #36619
Thanks. It is a factory belt and I have cleaned everything and with cover off both clutches appear to be working well. The shim to secondary sounds like my next move. I assume the shims are a dealer item.
Again thanks for ideas.
Old 06-14-2013, 05:50 AM
bgirard420's Avatar
Member #11494
Drive belt issue
They are a dealer item. If you look at your primary, belt should be right in the center of it, not rubbing on either sheave.
Also you should be able to "stretch" the belt at the center point between the primary and secondary about 1/4"(aka belt deflection). At least this is the amount for mine yours may be more or less.
2010 Polaris 500 HO
Drive Belt Going Out?? Blackhawks1 ATV Repair and Maintenance 3 08-16-2012 09:34 PM
Drive Belt sammer4u ATV General Discussion 1 06-20-2011 09:11 AM
drive belt meric ATV Repair and Maintenance 7 05-01-2011 09:53 PM
Drive Belt chris223401 Polaris Sportsman 6 10-09-2010 07:12 PM
Drive belt Mistavicious Polaris Scrambler 3 05-24-2010 10:59 AM
