04-20-2010, 06:18 PM
Member #4435
95 scrambler elec start problem
hello to everybody on here just joined the site. Im havin a problem with my electric start on my 95 scrambler 400.heres what i got, when i hit the button for elec start alls i get is a click out f the selenoid. i just put a new starter and bendix in it less than a year ago, the battery is not that old. i just wanted to know if anybody had an idea of where to start. thanks
04-20-2010, 07:06 PM
Hey welcome to the board!
04-21-2010, 09:26 PM
Member #2311
welcome!
1998 polaris 425 magnum 4x4
super swamper vampire tsl
3 inch lift
500 h.o. carb and airbox
plastic fenders and rack swap
relocated radiator
winch
1995 polaris 400 xplorer 4x4 R.I.P
1998 kawasaki 220 bayou
1998 e-ton 90
04-22-2010, 02:40 AM
Member #4280
my remanufactured starter over 200 dollers lasted about a year i took it apart and water had gotten in and ruined it.the seales on these things suck.i have a 400 sport,same motor as 400 scrambler.a friend of mine pit his second new starter on and this time he put silacone arround caseing where the rubber seal is .i will do this on my next starter,for now just pull starting.good luck .
04-22-2010, 06:34 AM
Member #2311
i just had my starter rebuilt for the same reason! went out in water deep enough to cover the starter and later that day CLICK CLICK!!! but i got it back 2 days ago and its just fine now!
3 inch lift
relocated radiator
winch
1998 e-ton 90
04-23-2010, 07:52 AM
Member #3476
Welcome aboard. If I can ever be of assistance, don't hesitate to ask.
Take care,
04-23-2010, 05:49 PM
Member #4351
if you have a multi meter place the positive were the cable is on the starter and ground the neg to the frame have someone press the button if the power is getting down there (around 12 volts) then the starter is dead. Just did this with 96 300 express.
04-26-2010, 05:11 PM
Member #2465
use a jumper wire or screwdriver to jump the selnoid if it starts its the selnoid if not it could be the starter or poor connections on ground wire or power wire.
1995 polaris 300 electric start problems, 1995 polaris scrambler 400 wireing diagram, 1999 polaris 500 scrambler electrical free, 2001 polaris scrambler electric start issues, 95 polaris 400 xplorer firing problems, 96 scrambler electric start not working, 99 polaris scrambler starting, electric start on a 99 polaris scrambler 400, how to work on 95 polaris scrsmblers, not geting electric to starter polaris, polaris 400 electric start, polaris 90 scrambler starter problems, polaris scrambler 90 starter problems, polaris scrambler starter clicks, polaris scrambler starting problems, polaris xplorer 400 electric start, scrambler electric start, stareter install on a 95 polaris scrambler, starter solenoid for scrambler 400, why wont my polaris scrambler electric start work
