05-20-2010, 04:10 PM
Member #4979
clicking sound
Hello i am new to this site. I have a 425 magnum and went to start it the other day and all it did was click it is getting power to the solienoid but not to the starter and really dont know how to take the starter off so any help is much appriciated. Also i pulled on the pull rope and i pulled it all the way out and now it wont go back in so i need to fix this to.
05-20-2010, 04:26 PM
05-20-2010, 06:18 PM
Member #3476
Welcome aboard. If I can ever be of assistance, don't hesitate to ask.
Take care,
05-20-2010, 06:25 PM
Member #4665
possibly a bad solenoid or even dirty connections mud and junk likes to sit in there and rust them a bit hope it throws you in the right direction ....i guess you could put a booster cable on the starter wire side of the solenoid to bypass it and if it start you know you likely need a solenoid
05-20-2010, 07:31 PM
Member #2311
welcome ....if your solenoid is clicking take your starter out and rebuild it or have it rebuilt .
1998 polaris 425 magnum 4x4
super swamper vampire tsl
3 inch lift
500 h.o. carb and airbox
plastic fenders and rack swap
relocated radiator
winch
1995 polaris 400 xplorer 4x4 R.I.P
1998 kawasaki 220 bayou
1998 e-ton 90
05-23-2010, 10:37 AM
Member #4979
I put a booster cable on the solenoid but still clicking so i now have to take the starter off. I also took the cover off the pull rope cover and it is all broke the plastic peice that the rope sits in is boke and so is the metal peice that pulls out and starts the motor.
05-23-2010, 10:46 AM
are you positive the battery is 100% good. did the quad sit over winter? this is can happen all the time if the battery is drained of amps, the solenoid will just click
05-23-2010, 06:40 PM
Member #4979
the battery is one year old but i made sure it was charged up
05-23-2010, 06:58 PM
Member #4725
I am not sure on your quad but on my 94 sportsman 400 I had to pull the pull start off to remove 2 bolts from the starter so when you are in there you might pull the starter and check it too
05-24-2010, 07:38 AM
Member #2311
if you tried to jump it and it still clicked your starter is toast....well most likely brushes! mine did the same just a month ago! on your magnum the starter bolts are on the backside of the starter take off your seat and take out your air box. the bottom bolt sometimes binds up with the back of the clutch cover but you dont have to remove (clutch cover) it to change your starter. also pay attention to the condition of the o rings on the starter if any of them are bad replace them if not you could be in the same boat after the first time you go through deep water, which is exactly why i had mine rebuilt a month ago..LOL!
3 inch lift
relocated radiator
winch
1998 e-ton 90
atv clicking sound when starting, atv solenoid clicking, bayou 220 solenoid click, bypass a solenoid on polaris, bypassing atv solenoid, click noise start, clicking sound in a polaris 250, clicking sound when trying to start atv, kawasaki 220 bayou ticking noise, kawasaki bayou clicking noise, kawasaki byou 220 is making a ticking noise, my trailblazer making a clicking sound when i try to start, polaris 250 4x4 sounds like solenoid clicking, polaris 425 clicking sound, polaris 425 loud ticking noise from motor, polaris 425 magnum starter just clicks#gsc.tab, polaris magnum 325 starter solenoid test, polaris magnum rear end cliicking noise, polaris solenoid clicking, polaris trailblazer 250 ticking noise in rear
