05-28-2010, 02:06 PM
Member #5134
suspension on 08 sportsman 800
Hello all new to the site must say it has been quite informative thank you all I have solved a lot of issues and you have answered a lot of my questions. First off what setting on the stock rear suspension would you recommend for a 190 lbs advanced rider that has a full cargo box and quite often a passenger. I have also noticed quite a few people asking which way to turn the adjustment nut and what tool to use. I myself remove the tire and hook one end of a 1" heavy duty ratchet strap to the bottom of the spring. I then loop the other end over the top of the strut and back to the bottom of the spring on the opposite side. Tighten the strap until there is a visible space. After that you can pretty much turn it by hand.
05-28-2010, 02:57 PM
Member #3440
you can try different positions to suit your needs, sounds like you might have to crank them up the whole way
RIDE ON !!
2010 Sportsman 850 XP EPS
2008 Sportsman 400 H.O.
05-28-2010, 03:54 PM
Member #5134
reply
ive been ripping on the softest setting and like the ride just dragging through the deep stuff. wife is light beer is heavy lol. will try medium setting see how that goes. thanks for the input. also dipps hard in corners, down hill and breaking up front any sugestions?? only have 400 km on the machine are the springs even broke in yet??
05-28-2010, 07:06 PM
Welcome to the boards!
05-28-2010, 09:09 PM
Member #2311
welcome!
1998 polaris 425 magnum 4x4
super swamper vampire tsl
3 inch lift
500 h.o. carb and airbox
plastic fenders and rack swap
relocated radiator
winch
1995 polaris 400 xplorer 4x4 R.I.P
1998 kawasaki 220 bayou
1998 e-ton 90
05-29-2010, 05:06 AM
Member #5134
Hey team im putting new skins on the 800 was thinking 28" zillas any input would be apprieciated.
05-29-2010, 05:55 AM
Member #3440
going to need a lift kit and clutch kit
RIDE ON !!
05-29-2010, 06:14 AM
Member #5134
how bout the 27" ??
05-29-2010, 06:29 AM
Member #5134
thats the kind of input i was looking for. dealer said they fit without rubbing and the driveline can handle them. then again there in the buisness to make money right. I have doubts about clutch kits ive heard horror storys about them and dont really want to compramise reliability. What tire size would you recomend??
Member #5134
Thanks alot Slyder
2005 800 polaris sportsman front shocks ajustment, 2008 polaris sportsman 800 heavy duty rear springs, 2008 polaris sportsman 800 suspension springs, 2008 polaris sportsman 800 suspension upgrade, 2008 polaris sportsman suspension springs, 2010 polaris 400 ho shock adjustment, 2010 polaris sportsman 800 suspension upgrades, 28" zillas on stock 800 sportsman?, front shock adjustment sportsman 800, heavy duty springs 2008 polaris sportsman, polaris sportsman 800 front shocks, polaris sportsman 800 shock adjustment, shocks for 2008 polaris sportsman 800, sportsman 800 front suspension, sportsman 800 heavy rear springs, sportsman 800 rear springs, sportsman 800 suspension, sportsman 800 suspention forum, sportsman 800 tool shock, springs for 2008 sportsman 800
