Better Shoes/Feet for my Plow - Page 2 - Polaris ATV Forum
  #11 (permalink)
Old 12-17-2016, 03:22 PM
Uncledaddy's Avatar
Member #55035
Originally Posted by Buckwild View Post
Nice work Jack. I just welded some 1/2" or so metal plates on the bottom of my stock feet.use washers to adjust the up and down. The stock pads wore through the first time I plowed with it.
How does the pipe work on pavement? I got steep gravel driveway a few hundred yards long then have to plow a lil bit on side of state road. Worried that if I put pipe on it I won't be able to get enough snow off the paved part.
Just got in from plowIng everybody, it doesn't work as well on pavement as a normal cutting edge. Itll still move the snow, but tends to leave a light skim coat behind vs steel edge only
2014 Sportsman 550 named "Chapter 7"
Lots of mods and add ons
  #12 (permalink)
Old 12-17-2016, 09:16 PM
JackG79's Avatar
Member #79946
I still may try out that pvc / pipe on the bottom of the blade. as I think it would save some clean up where I plow over my lawn. I find in the spring/summer im putting back a lot of Sod.. atleast when it used to get plowed with a truck. I find that with my ATV it comes out a lot cleaner as the blade isn't half as heavy. But the feet I made worked great. little/ no wear at all on them, and they add a couple extra lbs to each side of the blade. I do want to get one of them winch/stop limiter switches so that I don't break the synthetic cable. I can see where it would be asy to break it lifting the blade.
2016 Polaris Sportsman 850 SP Metallic
2000 Suzuki Quadrunner LT 500 (*sold*)
2001 Suzuki King Quad 300(*sold*)
2005 Yamaha Grizzly 660 (Blue)(*sold*)
Past ATV's: (Classics)
1984 Honda 185S
1984 Big Red (ATC200ES)
1986 FourTrax 125
1986 Honda ATC 250R
  #13 (permalink)
Old 12-18-2016, 04:15 AM
rm25x's Avatar
Member #60714
Adding a pipe over the cutting edge was the best thing I have done. Huge improvement and doesn't tear up the yard or catch on cracks.
2015 Scrambler 1000 XP
- Maxxis Bighorn 2.0's on RZR Turbo wheels
- Polaris 2500 lb winch
- Polaris Ogio rear storage bag
- RAM X-Mount for GPS duties
- Polaris Heated Grips & Thumb Warmer
- Polaris White/ Black Handguards
- Quadboss Pile Driver 60" Plow
  #14 (permalink)
Old 12-18-2016, 05:14 AM
thewayout's Avatar
Member #24852
Guys, how does the pipe over the edge work when you have to push hard drifts? I had to plow some hard packed drifts this week. No pipe on my plow and the plow rode over the drifts. Eventually the plow did cut into the drift. I think with a pipe on the edge it would never cut into the drift. I like the idea for not digging into the sod
  #15 (permalink)
Old 12-18-2016, 06:29 AM
Uncledaddy's Avatar
Member #55035
EveRythings a trade off. Abs pipe over steel edge wont move gravel around like a steel edge, wont curl and tear up lawns like a steel edge...so flip side, an abs covered cuttIng edge wont cut in like a steel edge.
I do all my covered edge places first, then move onto places i can pull abs pupe off and go back to steel edge
  #16 (permalink)
Old 12-18-2016, 10:47 AM
JackG79's Avatar
Member #79946
Im in a position where my driveway is only about 100 foot long and it's dirt/gravel bottom. So I don't need to cut right down to pavement. I can leave a few inches behind and me and my wife both have 4 wheel drive, so for me the trade off is owrth it. I don't mind not being able to scrap the ground so much, as it saves me a lot of yard/road work. On the other hand, someone with a long paved road would want to scrape right down to the tarmac so that they would get bare pavement when the sun came out. they wouldn't want the pipe, but the blade instead.
1984 Honda 185S
1986 FourTrax 125
1986 Honda ATC 250R
atv plow blade manual
Save me money Forklift Polaris Sportsman 4 05-22-2016 12:01 PM
Front suspension squat with plow use Tech77 ATV Brakes & Suspension 14 04-09-2016 11:37 AM
Atv plow wings and atv rear plow geerig ATV General Discussion 25 01-17-2016 08:44 AM
Looking for a manual plow lift for 07 sportsman with glacier plow mc1984ss ATV General Discussion 0 01-07-2016 07:20 PM
2014 Sportsman XP 850 H.O. EPS Pearl White LE ATV Snow Plow SubZeroCarvings ATVs For Sale 5 01-04-2016 05:03 PM
