2012 Sportsman XP to highlifter edition retrofit - Polaris ATV Forum
post #1 of 14 (permalink) Old 11-28-2016, 06:13 AM Thread Starter
cbroccolo's Avatar
Hey folks, new to the forum but felt obligated to share some insight about converting normal sportsman xp's to a highlifter edition. There's nothing currently out there that I could find aside from the actual manufactures technical drawings of the HL edition. So ever since they came out I've been wanting to integrate the bumper and the snorkel kit from it, I finally bought everything and decided to give it a go. Turned out really well and am extremely happy with the final product. It can be done....decided to make a little video of my progress and help better show what needs to be done
https://youtu.be/exOBd05Ld00
cbroccolo is offline
post #2 of 14 (permalink) Old 11-28-2016, 08:50 AM
Gulf550's Avatar
That's awesome. Thank you for sharing. I'm doing something similar with my 2010 850. I'm working on the snorkel now. I will post some pictures for you once I'm done doing it.
Gulf550 is offline
post #3 of 14 (permalink) Old 11-28-2016, 08:57 AM Thread Starter
cbroccolo's Avatar
I knew I couldn't have been the only one wanting this done...I have tones of pictures and could supply you with the part numbers if anyone needed. Just let me know, curious how it go's for you.
post #4 of 14 (permalink) Old 11-28-2016, 11:21 AM
Lollygagger77's Avatar
Yeah, fill this thread up into a how too? I would like to know what it cost you too (if you don't mind). I know that you can buy the factory looking snorkel fin for the can am and it makes regular outlanders look like XMR's, and that is a big deal here in MN as we are not allowed to snorkel our machines to any higher the 6" above factory intake. So those XMR look alikes are not getting stopped (bastards, LOL), so if I could get mine to look like a HL, then I will try...
NEW ADDITION: 2016 RZR 900S w/EPS
2012 Polaris 850 XP HO w/EPS
-28" Terminators
-HD Springs and JCCAPRI bushings
-QSC Clutch kit
-3500# Polaris winch with Synthetic Rope
-Polaris Front Brush Guard
-Polaris Lock n Ride front and rear storage
-Polaris Mid Lock n Ride Windshield (smoke)
-60" Warn ProVantage Plow
-Symtec Hand Warmers
-Quadrax Rear seat w/foot rest kit from ATVSUPERSTORE - Square Tube
Old Machines:
2006 Sportsman 800 EFI, 2005 Sportsman 700 Carb, 2004 Sportsman 500HO Carb, 2000 Sportsman 500 Carb
Lollygagger77 is offline
post #5 of 14 (permalink) Old 11-28-2016, 05:58 PM
weasel850's Avatar
The stealth snorkel would be legal in MN lolly. The air intake is where the gas tank normally is and the pod isn't much higher. I agree the highlifter would be the way to go but it might cost a lot.
I would be interested I your build as well.
2010 850 xp
2.5'' RDC lift kit
Cobra axles all around
31'' outlaws on sti beadlocks
Stealth snorkel
3500 viper winch
Homemade bumpers front and rear
Homemade rack extends with ammo cans
Hers
2010 550 xp
27'' mudlite xtr
Homemade front bumper and rack extenders
weasel850 is offline
post #6 of 14 (permalink) Old 11-30-2016, 08:35 PM
Gulf550's Avatar
Right now I have not relocated my battery. I like the idea of moving it lower, but also would like to move it to where the 2009 model has it, under the seat. I already have the highlifter low profile rad relocation kit. So I can't do center risers on the snorkels. I'm doing a little custom design on my risers, but having a problem on how I would get the front rack off. I will get some pictures put together and post them up here. Thanks again for video.
Gulf550 is offline
post #7 of 14 (permalink) Old 12-15-2016, 08:12 AM
Gulf550's Avatar
Okay, Like I promised here are some pictures of how mine turned out. I have a different Rad relocate than you. I did not have enough room to do center stacks.
I have a 2010 850xp w/EPS:
First picture is the overall finished product :
Now, something that worried me was the the airbox cover. So what I did was purchased the seal from an 850 highlifter and remove the foam pad that goes around the cover.
I will buy some o-rings to go around the mounting hardware. I just used what I had in my garage to help seal it.
Now I created a mouthing plate to help keep the snorkels stable. I made it so I can still remove the front rack.
Now some of the additional things I put on were the winch switch, highlifter 1000 wheels and mud bar.
Gulf550 is offline
post #8 of 14 (permalink) Old 02-03-2017, 10:11 AM
TxReaper86's Avatar
I have a 2015 850 I would like to do this with. How did you attach your battery to the old rad location?
2015 Sportsman 850 XP H.O. White Lightning
27" ITP Mega Mayhems skinnies front fat back
KFI Winch Mount
Superwinch LT3000
Wild Boar Radiator Relocation
Mcm speakers with hydra amp
TxReaper86 is offline
post #9 of 14 (permalink) Old 02-04-2017, 11:29 AM Thread Starter
cbroccolo's Avatar
If you have a look at the video I think I do a little close up. There's a cross member between two fame tubes, it fit in there pretty well and I just used two stainless hose clamps to keep it in place. haven't had an issue since..I would suggest attaching all your positive and negative leads to the battery prior to mounting in place again. Was a Bitch to do it once it was mounted in place
post #10 of 14 (permalink) Old 02-06-2017, 10:43 AM
TxReaper86's Avatar
Awesome! Thank you. I kinda fast forwarded through the vid and I guess missed that part.
KFI Winch Mount
Superwinch LT3000
Shock interchange TDMax Polaris XP 7 07-13-2016 05:21 PM
