Help! Sportsman ECU removal - Page 3 - Polaris ATV Forum
post #21 of 21 (permalink) Old 01-03-2017, 07:30 AM Thread Starter
bmerwin's Avatar
Well i am back from my trip and i can definitley tell an increase because of the flash.
Not once did i hit the rev limiter on my HL like i used to before (which was pretty often).
The low end stayed somewhat the same and no i still cant pop a wheelie from sitting still.
The Mid range is what really came alive, once the bike gets rolling you can really feel it squat the back end and start pulling away.
My fans did seem to come on more often but ran for a shorter amount of time than before.
I was still running my dobeck 3.5 and did have some popping when i let off of the throttle so i hope the reflash will cure that.
Besides that im pretty content with what i got, i know my gear reduction limits me alot so im sure on a normal sportsman XP you will really notice a difference.
Mine-
2016 Polaris Sportsman 1000 Highlifter
RJWC Exhaust
Dobeck 3.5 Fuel Tuner
RVS Performance ECU flash
Snorkel Kit
KFI Tiger Tail
HD ATV Gear Pinion Plate Upgrade
High Lifter DHT Rear Axles
Uni Air Filter
Rogue Offroad Radiator cover
Dalton Industries Primary Spring
Mictuning 14" LED Light bar
2016 Polaris 1000 RZR Highlifter
Mictuning light bar
KFI tiger tail
RTIC Coola
Chupacabra Side mirrors
RVS Air filter
2016 Dodge Ram 2500 6.7L Diesel
Wasted Wages SOMD
#wastedwagessomd
bmerwin is online now
Shock interchange TDMax Polaris XP 7 07-13-2016 05:21 PM
