Help! Sportsman ECU removal - Polaris ATV Forum
Old 12-01-2016, 04:17 AM
bmerwin's Avatar
Member #64865
I am trying to remove my ECU to send to RVS performance for the ECU tune off of my 2016 Sportsman HL 1000 and having an incredibly hard time getting the ECU out. Has anyone else done this before? What kind of tabs are on the bottom? I can get my hand to it but it is extremly tight and I have no idea what im feeling for (its like my first girlfriend all over again)
Mine-
2016 Polaris Sportsman 1000 Highlifter
RJWC Exhaust
Dobeck 3.5 Fuel Tuner
RVS Performance ECU flash
Snorkel Kit
KFI Tiger Tail
HD ATV Gear Pinion Plate Upgrade
High Lifter DHT Rear Axles
Uni Air Filter
Rogue Offroad Radiator cover
Dalton Industries Primary Spring
Mictuning 14" LED Light bar
2010 Sportsman 500 H.O.
Snorkeled
Wheel Spacers
4.5" Lift
HMF Swamp Series XL
HMF Jet Kit
KFI 3500 Winch
2016 Polaris 1000 RZR Highlifter
2016 Dodge Ram 2500 6.7L Diesel
Wasted Wages SOMD
#wastedwagessomd
Old 12-01-2016, 07:28 PM
x omerta x's Avatar
Member #5222
I'm guessing it's the same as my 570 it 4 torx screws two on top two on bottom took 5 min to get it out. Back in was a little more tricky but still easy
Old 12-01-2016, 08:16 PM
breakneck's Avatar
Member #69041
Took mine out of the 1000 the other day to send to RVS. The douche who put it in that tight ass location, with no slack in the wire loom needs to be curbed. That was probably the same guy that designed the ecu housing with all those sharp edges.
I wish that I could accurately tell you how I got it out. The tabs are not the typical ones found on electrical connectors. There is a hinge like system that needs to be rotated from the left side towards the right side of the bike. Of course it is located underneath the ECU and the connector. Once you get that hinge rotated, you should be able to lift up on the ECU body and it should pull free from the connector.
I know my description sucks.
Old 12-02-2016, 04:18 AM
bmerwin's Avatar
Member #64865
Got mine out last night, ended up pulling almost the entire air box out and that was enough to get two hands back in there to rotate that lever down and lift up on the ECU, not without cutting the hell out of my hands i might add lol
I hope this ECU flash is everything Ryan says its going to be!
Mine-
RJWC Exhaust
Snorkel Kit
KFI Tiger Tail
Uni Air Filter
Snorkeled
Wheel Spacers
4.5" Lift
HMF Swamp Series XL
HMF Jet Kit
KFI 3500 Winch
Wasted Wages SOMD
#wastedwagessomd
Old 12-02-2016, 09:16 AM
breakneck's Avatar
Member #69041
It looked like i stuck my hands in a sack full of cats by the time I got that dang thing out. Then i immediately thought how in the eff am I going to get it back in? Will definitely rope someone in with much smaller hands to do it.
And you are right-it better live up to the hype!
I am surprised that there is not more talk on this forum about people buying this flash.
Old 12-02-2016, 09:19 AM
bmerwin's Avatar
Member #64865
I can see why some people wouldnt want to after the hell you have to go through to get it out! Then again if it was easy, everyone would be doing it.
Mine-
RJWC Exhaust
Snorkel Kit
KFI Tiger Tail
Uni Air Filter
Snorkeled
Wheel Spacers
4.5" Lift
HMF Swamp Series XL
HMF Jet Kit
KFI 3500 Winch
Wasted Wages SOMD
#wastedwagessomd
Old 12-02-2016, 11:52 AM
x omerta x's Avatar
Member #5222
Maybe because it's the HL edition some things are moved and harder to get at but I have done 2 570s and its straight forward and easy. Glad I lucked out
Old 12-10-2016, 11:19 AM
Neal_Fox's Avatar
Member #54914
I am curious to see what the reflashed ecm does on the 1000?
Sent from my SM-G935R4 using Tapatalk
Old 12-12-2016, 04:37 AM
bmerwin's Avatar
Member #64865
Just got mine in the mail yesterday, havent had a chance to throw it back in put it all back together yet. I will post something once i get a good ride on it.
Mine-
RJWC Exhaust
Snorkel Kit
KFI Tiger Tail
Uni Air Filter
Snorkeled
Wheel Spacers
4.5" Lift
HMF Swamp Series XL
HMF Jet Kit
KFI 3500 Winch
Wasted Wages SOMD
#wastedwagessomd
Old 12-12-2016, 02:31 PM
J_Eekhoff's Avatar
Member #48090
well what do you think?
"I've been doing so much with so little for so long, I can do anything with practically nothing"
-2015 850SP-
-SW terra 3500
-Uni airfilter
-28in Mega Mayhems
-F/R cecco frame braces
-NGK plugs
-10 inch Grote lightbar
-Custom front bumper
-Ricochet full skids
-QSC adjustable weight clutch kit
-Orange anodized front pinion cover
-Triangle ATV stealth snorkel kit
-Led low-beam headlights
-Highlifter Rad relocation kit
2000 Sportsman 500-
polaris 2500 winch, qsc clutch kit,27in executioners, Led Headlights
ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) FOR SALE KLCFLC Polaris Sportsman 1 11-21-2016 03:09 AM
3280431 ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) KLCFLC ATV New Members 0 11-19-2016 04:12 AM
Shock interchange TDMax Polaris XP 7 07-13-2016 06:21 PM
2002 sportsman 500 bearing carrier fishnfool ATV Brakes & Suspension 2 07-13-2016 10:50 AM
Softer rear shocks/springs? Unitoo1 Polaris Sportsman 10 04-25-2016 05:20 AM
