Synthetic winch cable? - Polaris ATV Forum
 1Likes
post #1 of 11 (permalink) Old 12-06-2016, 03:15 AM Thread Starter
AKNeal's Avatar
This may not be a performance modification, but I really didn't see a better place to ask my question.
So my winch cable has had it and I decided to replace it with a synthetic one. Does anyone have any suggestions? I was looking at the Polaris cable, but I've seen a few others online. What is the experience floating around out there?
Thanks!!
AKNeal is offline
post #2 of 11 (permalink) Old 12-06-2016, 03:53 AM
indyred570's Avatar
My winch came with the synthetic rope, no problems yet. I bought my winch from RVS Performance, here's a link to the website.
Replacement Winch Cable
2014 Sportsman 570 (Red)
Powermadd Hand Guards
Viper Elite 3000 Winch/KFI mount
Denali Snow Plow
Polaris HD Front Springs
Kenda Executioners
indyred570 is offline
post #3 of 11 (permalink) Old 12-06-2016, 06:35 AM
Uncledaddy's Avatar
Rvs is a great dealer, great products and a member here...^
Also, I would replace the fairlead with a new one or switch to a hawse, either way the thing should be new/flawless because anything worn/ruff from your steel cable will shorten rope life dramatically.
2014 Sportsman 550 named "Chapter 7"
Lots of mods and add ons
Uncledaddy is offline
post #4 of 11 (permalink) Old 12-06-2016, 04:19 PM
faawrenchbndr's Avatar
What ^^^ they said!
2012 550 EPS LE, Blue Fire
Cecco frame braces
JCCapri bushing kit
Maxxis BigHorns
Ricochet skid plates (full kit)
Polaris rear rack extender
Polaris front brush guard
Warn ProVantage 2.5k winch
AmSteel Blue synthetic winch rope
Custom billet hawse fairlead
Denali 60" mid mount plow
faawrenchbndr is offline
post #5 of 11 (permalink) Old 12-06-2016, 04:25 PM
CoachCMak's Avatar
I just installed my first one, a new Moose synthetic winch rope, on Sunday before the snow. Hopefully we get some more to really test it out.
Live life, you only get one.
2004 Sportsman 500 H.O. 4x4 (6,100+ miles)
Carlisle AT489 25x8-12 fronts
Carlisle AT489 25x11-12 rears
Warn 2,500 Winch w/Moose synthetic winch rope
CoachCMak is offline
post #6 of 11 (permalink) Old 12-06-2016, 05:35 PM
Uncledaddy's Avatar
Much up/down...gunna break. Too much wear and tear/heat build up on 1 short 8" section of it. Not a flaw of rope.because cable wears just the same, benefit is rope is a quick pocket knife, new knot repair and your on your way. But for plowing duties, I listened to these guys 2 yrs ago and used a section of 2" strap just for plowing and never had a breaking issue. CabLe with former quad, it'd get repaired an average of 8 times a winter. The rope when I first tried it on my new quad/plow set up made it thru half the day before it broke.
So just keep the strap idea in the back of your mind if/when it begins breaking from alot of up/down plow cycling.
post #7 of 11 (permalink) Old 12-06-2016, 07:41 PM
CoachCMak's Avatar
Much up/down...gunna break. Too much wear and tear/heat build up on 1 short 8" section of it. Not a flaw of rope.because cable wears just the same, benefit is rope is a quick pocket knife, new knot repair and your on your way. But for plowing duties, I listened to these guys 2 yrs ago and used a section of 2" strap just for plowing and never had a breaking issue. CabLe with former quad, it'd get replied an average of 8 times a winter. The rope when I first tried it on my new quad/plow set up made it thru half the day before it broke.
I've been reading about the strap idea. I like it. I really think I'm going to do that. I've put on the 50 foot rope so I don't have to take it off, put it on every time I want to take off the plow and play. So I think the strap will be the ticket!!
post #8 of 11 (permalink) Old 03-04-2017, 08:14 AM
buccaneerfan's Avatar
I have had problems when it gets packed with snow and ice reversing inside the winch. Then you basically have to cut it and start over. It helps when you wind it up to keep as much tension as you can and slowly move the cable side to side as it winds so nothing binds up. Otherwise I have loved it. It's nice and light and super easy to work with.
Sent from my SM-G920V using Tapatalk
buccaneerfan is offline
post #9 of 11 (permalink) Old 03-18-2017, 03:39 PM
Surfinpig's Avatar
What's the strap you guys speak of? I break my rope all the time plowing.
Surfinpig is offline
post #10 of 11 (permalink) Old 03-19-2017, 06:44 AM
indyred570's Avatar
Here's an example of one: How to- Strap for atv snowplow instead of rope or cable
Surfinpig likes this.
Denali Snow Plow
Kenda Executioners
How to- Strap for atv snowplow instead of rope or cable Uncledaddy ATV General Discussion 25 03-22-2017 08:54 AM
Harbor Freight winch cable drspec ATV Gear and Gadgets 20 12-19-2016 01:20 PM
winch cable HowdysMom ATV General Discussion 8 08-29-2016 04:56 AM
Winch cable vs. winch rope wcfcff545 ATV General Discussion 25 05-08-2016 01:06 PM
why is synthetic rope stronger than steel cable Uncledaddy ATV General Discussion 25 11-29-2015 04:54 PM
