2000 Sportsman 500 6x6 Clutch/Power Upgrades - Polaris ATV Forum
Old 01-24-2011, 08:20 PM
Bodi's Avatar
Member #11394
I have a 2000 Sportsman 500 6x6 with about 400 original miles on it. I only use the bike to plow snow at 5K' and retrieve Elk from elevations between 8K'-10K'. Can anyone suggest a Clutch Kit/Exhaust or other Power adding modifications to give the machine a little extra at high elevation.
Old 02-18-2011, 08:39 PM
Mark Gordon Cooper's Avatar
Member #12158
Not sure about power Upgrade, could you help me with tightening the main drive chain
Dear Fellow 2000 6x6 owner,
I use my 6x6 on heavy rock and incline in Arizona, the main drive chain, first chain from the motor to the first drive spoket, which then drives the second set of wheels, is loose and I can't see the tightening mechanism. Do you know how to tighten this main drive chain?
My sportsman front two wheels are shaft driven, without chain.
The back four wheels are chain driven but the chain from the motor to the first sproket, keeps coming off when clearance is issue. How does "One" tighten the chain?
Now, logic tells me that to increase power, better intake, more air. Then more exhaust. Possibly a new transmission belt so the clutch will grab quicker.
Mark G. Cooper
Old 02-19-2011, 06:55 AM
Old 02-19-2011, 07:08 AM
Member #12158
Smile Chain Slack in front axle
I understand the last axle chain adjustment but the chain adjustment from the motor to the first sprocket, that is where I need help.
Old 02-20-2011, 06:45 PM
elmerkit's Avatar
Member #3805
Welcome aboard oem parts would suite your need, no need for performance parts for the job.
Old 02-20-2011, 08:21 PM
Member #12158
Since I work on rocky places, I decided to sell it
I placed an Posting in Colorado, sold the 2000 Polaris for $3500 to the very first person who replied. I am taking it to Alburquerque, NM, Wednesday to hand it off, she is coming from Colorado Springs. I sold her the trailer as well, package deal for $4000, Cash.
The reasoning, the chain is exposed to the bottom, without chain guards, the rocky ground I deal with most all of the time, will only push against the chain often, it will come off many times while I am on my Hill Side so, chain linkage will not work for me. Shaft drive is the only possible solution for me.
Prior to this Polaris, I have the Quad of all Time, a Vintage Honda 300TRX full time AWD, shaft driven 1991. Due to being shaft driven and skid pads, I drove on rocks but never had this problem.
I never had any problem when just driving the Polaris on normal clearance areas. So, I know this Polaris chain issue is only a problem for Arizonan's with lots of rocky terrain. I can't have chains coming off, when I am on a 35 degree hillside, especially with a 6x6 which weighs 895 lbs, this is tough to pick up and hard to turn. Now, the new 6x6 Big Boss, 2009.2010.2011, are shaft driven, these would not be a problem for me but problem is $10,000 to purchase.
So, I sold it and will probably purchase some shaft driven alternative or just a Rock Crawler Jeep.
2000 polairs sportsman 500 6x6 chain adjustment
2000 polaris 6x6
2000 polaris sportsman 500 6x6
chain drive issues polaris 6x6
how do you tighten the chain on a polaris 6 wheeeler
polaris 2000 sportsman 500 6x6 new transmission
polaris 500 6x6 mods
polaris 6x6 2000 modify
polaris 6x6 chain adjustment
polaris 6x6 clutch kit
polaris 6x6 front chain adjustment
polaris 6x6 upgrades
400 sportsman upgrades? peterbilt Polaris Sportsman 6 11-05-2010 04:43 AM
2008 sportsman 300 power upgrades firedude26 Polaris Sportsman 0 05-18-2010 07:08 PM
2000 Sportsman Clutch Cracked getnit1 ATV Repair and Maintenance 5 04-08-2010 05:56 AM
How much power diff between a 2000 sportsman 500 and a H.O. SEA Polaris Sportsman 10 10-01-2009 01:09 PM
Sportsman 850 Upgrades Pinochle767 Polaris XP 4 07-08-2009 01:33 PM
