Convert 2004 sportsman 700 efi twin to carb system? - Polaris ATV Forum
post #1 of 4 (permalink) Old 01-04-2017, 06:10 AM Thread Starter
cookwv's Avatar
My 2004 700 has a bad asm harness for the fuel injection system and Polaris doesn't make it anymore the dealer is stuck as how to fix, has anyone converted an efi system back to a carb system?
cookwv is offline
post #2 of 4 (permalink) Old 01-04-2017, 06:40 AM
stave7119's Avatar
Not sure if it has been done or not, but I would guess it would be expensive. You will obviously need the hard parts. Carb, fuel pump and fuel lines, choke cable and throttle cable. But also I would speculate that you will need some different harness parts and at least the ECM.
Has the EFI system changed that much over the years. Would it be possible to use some of the parts from a later model EFI system to make it work? Not sure how long they made the 700. If the hard parts are good, then maybe something from a later 500, 600 or 800 might work.
1st Machine
2001 Magnum 325 with a blown engine; rebuilt 2004. Broke timeing chain 2016 rebuilt again and still running. Warn winch and Moose 60" plow
Wife's machine:
2007 Sportsman 500 EFI, Polaris Winch, 26" Bear Claw HTRs on Moose 427x Wheels. 12x7 front, 12x8 rear, QSC Clutch Kit
My Trail Machine:
2004 Sportsman 600 Twin, 25" RipSaw Tires on stock steel wheels, Moose rear box
Completed Project machine:
2001 Magnum 325 MOSE with a blown engine. Transplanted a 2005 Magnum 330 engine. Committed suicide on the trail Oct 2016. Spun Rod Bearing after oild cooler line failure. Rebuilding Engine.
stave7119 is offline
post #3 of 4 (permalink) Old 01-04-2017, 06:55 AM
cariboo's Avatar
change your dealer,if he can't get a harness he can make one or he should not be in business
cariboo is offline
post #4 of 4 (permalink) Old 01-04-2017, 07:27 AM
MNTNBKR's Avatar
When I read the subject I thought WTF? Why would anyone want to do that? Now it makes sense, but see below.
Good point. Best case, they should be able to salvage the good parts of your harness and repair the damaged parts. Worst case, they should be able to build a new harness.
Additionally, looking here I don't see any "discontinued" parts in the electrical section. I'm not sure what the "ASM Harness" is though. At the very least, I've found ebay to be a good source for old parts from part out machines..
I wonder if they're trying to get you to upgrade to a new machine.
2016 Can-Am Outlander Max XT 650, Brushed Aluminum
2015 Sportsman Touring XP 1000 Bronze Mist, Uni-Filter, 2" lift, 28" Bearclaw HTR's, Cobra HD front axles, Glacier Pro Plow system
2008 Can-Am Outlander Max XT 400, Red
1987 Manitou 24' Pontoon w/ 25HP Merc, bimini top, & propane grill
2014 Aluma 8112 utility trailer (my 'lil toy hauler)
1990 Honda Fourtrax 300, blue, plow machine (Sold)
1986 Yamaha Moto 4 225 (sold)
MNTNBKR is offline
Service manuals cookies ATV Repair and Maintenance 981 04-23-2017 11:10 AM
2004 Sportsman 700 Twin EFI - obsolete part? cookwv ATV General Discussion 9 01-09-2017 05:19 AM
Sportsman 700 Crankshaft Brawndo ATV Parts Wanted 2 06-07-2016 05:18 PM
