My Frame Brace Install & Question - Polaris ATV Forum
 2Likes
post #1 of 11 (permalink) Old 04-13-2017, 06:52 PM Thread Starter
jhalpinjr's Avatar
So Guys/Gals,
I installed my front Frame Bracers (Cecco) tonight. Went off without a hitch. Everythign lined p well- I was surprised (and happy) because I ride fairly hard.
I noticed on Ricks site he also sells rears.
Have any of you done the rears also? I am hoping the Front are the more important ones to do?
Not sure why all 4 aren't in a kit......
2016 Sportsman Touring 850SP
Ricochet Full Armor- Anodized Red
Rick Cecco Frame Bracers
Gorilla Whips - Silverback LED Whip
ATV-Guru Rear Bumper
RAM Mount- Use Polaris RideCommand App
jhalpinjr is offline
post #2 of 11 (permalink) Old 04-16-2017, 04:42 PM
AAnderson88's Avatar
Ordered front and rear together. I put them on a couple weeks ago. Did it as a precaution don't want to run into trouble in the future. I ride pretty hard also.
jhalpinjr likes this.
2015 SPORTSMAN XP1000 - BLACK PEARL
Front & Rear XP Bumpers
Polaris 2500HD Winch Synthetic Rope
Lock & Ride Front Cargo Storage
Symtec Heated Hand Warmers & Polaris Handguards
Cecco Front & Rear Frame Braces
Kimpex XP Rear Box Seat Lock & Go System
HD ATV GEAR Pinion Cover - Red
Ricochet Full Skid Plates w/Red Anodoized A-Arms
Kenda 28" Bear Claw HTR's
**POLARIS EXHAUST UPDATE DONE AFTER BLOWN EXHAUST & MELTED PLASTICS**
AAnderson88 is offline
post #3 of 11 (permalink) Old 04-16-2017, 06:59 PM Thread Starter
jhalpinjr's Avatar
Well I contacted Rick and purchased the rears. They are on there way. Hope they install as easy as the fronts.
The fronts were easy peasy. No issues at all.
post #4 of 11 (permalink) Old 04-18-2017, 07:52 PM Thread Starter
jhalpinjr's Avatar
Whata Fkn B&^&*^$&^$%(& it was to put the rears on. Half hole off... Tires removed...and the "BING"
I remembered someone on this forum used needle nose vise grips in the hole, and then regular visegrips on the side to hold the plate in the proper position.
That was the ticket! After doing that the braces were on in 5 minutes.......
So whomever that was that posted that idea: Many thanks and I owe you a few beers!
Oh and one more thing: I had to grind the brace and repaint the bottom to make clearance for the brake line. There was NO way the line was going to fit without crushing it. MKe sure you have a grinder, dremel or wheel if you decide to out these on!
post #5 of 11 (permalink) Old 04-19-2017, 06:56 AM
thumper1500's Avatar
Yeah, I had to grind the corner (and paint) on my front brace because one corner was hitting a little. No big deal, but Rick, in case you're reading... Anyway, the kit I installed for my Tatou T4S tracks had a frame brace for the rear as part of it, so I didn't have to by it separately.
2015 Sportsman XP 1000 Touring
Bronze Mist
QSC Clutch Kit
Ricochet Ultimate Armor Kit
HighLifter 2" lift kit
Kenda Bearclaw HTR 28" tires
Cecco frame braces
Cecco billet front pinion cover
Guru silver bumpers
12" LED lightbar
2" hitch w/bottle opener
Mid smoke windshield
Tatou 4s tracks for the snow
Synth winch line and Hawse fairlead
LED headlights
Wired for electric helmets
thumper1500 is offline
post #6 of 11 (permalink) Old 04-19-2017, 11:26 AM
Weird I didn't have to do any grinder of the braces. Front and Rears fit on fine with the brake lines going over & under. The only delay I had was on the fronts and moving the winch, but that was still only a few bolts.
post #7 of 11 (permalink) Old 04-19-2017, 03:27 PM Thread Starter
jhalpinjr's Avatar
Wish mine were that easy. The fronts were great. The rears sucked azz. Lol
post #8 of 11 (permalink) Old 04-20-2017, 04:08 AM
RickCecco's Avatar
This is a first on having to modify the frame braces I have heard of in 3 years - the early design has been updated 3 times to make installation easier so lets figure out the issue..
For instance if you skipped the instruction / steps of: (1) removing the skid plate or (2) loosening the brake line clamp to pull slack out of brake line (there is plenty slack BTW) you could have this issue. Skipping these steps seem like not big deal but its no different than trying to replace a tire with the wheel still bolted to the ATV - it can be done but it be much easier if you took the wheel / tire off. And I know people DO NOT WANT to pull the skid plates.....
If I remember correctly you did have an issue understanding how to install the rear braces which you emailed me for further instructions beyond what was provided?
PLEASE always email me pictures or diagram of issues so we can review it and make possible changes.
I am not hear to defend, take blame or point fingers - I am here to HELP so if I can make a change to the design I will.
Thanks,
Rick
RickCecco is offline
post #9 of 11 (permalink) Old 04-20-2017, 04:53 AM Thread Starter
jhalpinjr's Avatar
Thanks,
Rick
Hi Rick! Thanks for the feedback, and your help. Yes you did help me with the instructions in regards to the bolts and where the bracers actually went on the rear A arms. I did take off all the tires and skids plates as I was also prepping for new Ricochet Skid Plates. I removed the P clip holding the brake line- I actually didn't have much slack to work with at all- none to pull from forward, and the amount in the rear was minimal to cover suspension travel?- possible shorter line? Maybe the slack was secured much further up in the front...
With my bracers in the fully installed position I had less than 3/16" clearance to the diff- not enough clearance for the brake line. (actually couldn't even seat the bracer in the full install position with the brake line interference-again this is the rear most piece, where the line is to go above the brace) Pictured from the install position I had to grind the right side right where the horizontal part meets the diagonal that runs up to the mounting hole. I removed about an 1/8" depth of material, rounded the edges and used exterior enamel paint.
I will try to post some pics and send to you as well. I am hoping i can still see it clearly - as I just put the full Armor Ricochet skid plates on at completion of the brace project. I will check it out tonight when I return from work.
I love how stout the bracers are. Definitely give me piece of mind on this part of the frame!
post #10 of 11 (permalink) Old 04-20-2017, 05:42 AM
RickCecco's Avatar
Thanks,
Rick
Please send the pictures so I can review this. I know the frames and rear differentials have not changed in size or shape in that particular area since 2009 so I am very curious.
Moose Front Bumper install question 2009XP550 Polaris Sportsman 0 03-17-2017 07:19 AM
2005 trail boss question on the frame dknight903 Polaris Trail Boss 2 12-08-2016 12:34 AM
Frame Question tech413 Polaris Predator 3 10-01-2016 06:34 AM
Frame brace Sport570 Polaris Sportsman 570 4 07-25-2016 09:26 PM
13 scrambler broken frame pllanos85 Polaris Scrambler XP 7 06-10-2016 05:54 AM
