Auxiliary light, switch, relay question - Polaris ATV Forum
post #1 of 11 (permalink) Old 05-04-2011, 09:51 AM Thread Starter
mariano550's Avatar
Hello everyone, I know you can give some directions with this.
I have everything ready to connect auxiliary lights to my 550 XP.
I have a pair of Hella FF50 with a Hid Kit, relay, fuses and switch. Everything tested and working.
My question is, as you know, Polaris 550 XP has extra hot wires (key turned on) under the pod, and I need 2 hot wires for my installation: 1 for the switch and 1 for the relay.
I will take this hot wire to connect it to the switch...may I use the same wire to connect it to the relay or should I connect the relay straight to the battery ?
Thanks in advance for your help
Mariano
As the speed of light is greater than that of sound, some people seem bright before you hear the stupid things they say.
mariano550 is online now
post #2 of 11 (permalink) Old 05-04-2011, 10:25 AM
Tool Man's Avatar
I would connect the relay directly to the battery. The idea of a relay is not not have high current passing through a switch. The power wire for the switch can be a smaller gauge wire than the wire to run the relay and lights. Also don't forget to fuse BOTH the wires coming off the battery.
Tool Man is offline
post #3 of 11 (permalink) Old 05-04-2011, 10:32 AM Thread Starter
mariano550's Avatar
Thanks for your answer. Yes, that's the idea of a relay and I have both positives behind a fuse.
Thanks again!
post #4 of 11 (permalink) Old 05-04-2011, 11:09 AM
cwlongshot's Avatar
I do not understand the two positives.
As stated the really is for power and a lo-voltage to the switch as a trigger.
The relay will have one ground one power. Power should be fused. Then it could have one or two wires for the accessory. In your case light. If only one wire you simply split it for the two lights.
Then last is the trigger wire. This is connected to what ever you want the lights to come on with. Like existing lo beams. Or pod lite.
You could switch the ground wire but that would require a high amperage switch. Or you could switch the trigger wire. This is what I suggest.
Good luck,
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
cwlongshot is offline
post #5 of 11 (permalink) Old 05-04-2011, 11:19 AM Thread Starter
mariano550's Avatar
CW, the trigger wire is coming from the switch. And I need a positive for the switch because it has a light.
In the image you can see the diagram I'm usign.
Thanks for your help
post #6 of 11 (permalink) Old 05-04-2011, 11:22 AM
Tool Man's Avatar
If the trigger wire is positive, then you need a positive wire into the switch. That's where the second power wire is needed.
The other option is to run the relay with a negative trigger. to do this you would run a power wire from the battery to pin 30 of the relay, then jump power from pin 30 to pin 86. Pin 87 would be the output to the actual lights and pin 85 would be connected to the switch. The other side of the switch would go to ground.
If the switch is illuminated it changes how it needs to be wired and I can't remember how they are wired.
Hope it clears it up a little. There are other ways to wire things and everybody has their own style. I used to install car stereos, alarms and remote starters and used relays a lot. But I had to really think about it before connecting the wires each time.
Tool Man is offline
post #7 of 11 (permalink) Old 05-04-2011, 11:33 AM Thread Starter
mariano550's Avatar
Thanks again!!
You can see the way I'm connecting everything in the above diagram. I tested it and works perfect!
My question was about the power on the Pin 30 of the relay. I believe that I must wire it directly to the battery, and I will use an extra hot key wire under the pod for the switch.
Thanks everyone
post #8 of 11 (permalink) Old 05-04-2011, 03:25 PM
cwlongshot's Avatar
Talking
Originally Posted by mariano550 View Post
Thanks again!!
Thanks everyone
AHHHH.. a LIGHTED switch!! Of coarse!! Didn't think of that...
Other than that the drawings look good. YES the power needs to be direct to the battery. You should also run a fair sized wire. DC is like a water pipe, bigger is more flow. Heat is the enemy, heat in a DC wiring loom is resistance. Big wire is less resistance.... So run bigger wire. the ground is also best run directly to the battery, but is acceptable securely grounded to the frame.
Lock N Ride roof
LOTS more coming...
post #9 of 11 (permalink) Old 05-04-2011, 04:11 PM Thread Starter
mariano550's Avatar
Thanks a lot CW !!
I will use a 4mm wire directly to the battery for positive and ground.
Thanks again everyone!!
post #10 of 11 (permalink) Old 05-05-2011, 09:01 AM
jbf
jbf's Avatar
I did something similar but now your lights will come on without the ignition switch on. What I'm doing to mine is finding the "switch power" available in the pod. Connecting that through the light switch to the coil on the relay. Leaving the the straight battery connected to the lights through a fused line on the relay contacts. That way if the ignition switch is turned off, the coil has no power and the lights go dark. I don't want to find my battery dead because someone or something turned my lights on. Just a thought...
2011 850 Touring Super Graphite LE
25.5" Pitbull Rockers
2009 850 Tequila Gold LE
2008 800 Touring Red
25.5" Pitbull Growlers
2008 800 Touring Blue
26" Big Horns
jbf is offline
fog light switch location?. cvjoint Polaris Sportsman 16 12-09-2012 09:39 AM
light,on/off, override switch issues WFOWS6_IL Polaris Scrambler 1 04-28-2011 12:11 PM
Switch on side of light on 95 xplorer Belldenpugs ATV Repair and Maintenance 2 04-15-2011 11:25 AM
Headlght relay mod 2004 Sportsman 700... relay chattering. Rocky2 ATV Performance Modifications 4 01-30-2011 06:07 PM
Relay part number for 3 light mod. poboy74 Polaris Sportsman 0 02-13-2010 12:06 PM
