Old 05-31-2011, 05:57 PM
Bruce500's Avatar
Member #15599
I need help jetting
Hey, i have a 2007 predator 500 and i have a full fmf on and a k&n filter with the 6 uni holes in the air box. its getting plenty of air so its running a little lean. i have a whole jetting kit but dont know what size to put in it nor how to do it... any help?
Old 05-31-2011, 06:51 PM
Oh no another BRUCE on the board???? Welcome to the board BRUCE!
Old 06-01-2011, 01:31 PM
Ruvalcaba's Avatar
Member #15578
Your jet kit has to have a 160 main jet, that is the one I would use. Dont mess with the pilot. The main jet are the small ones and has the number on them. It's a simple mod the loose the bolts take off the carb turn it over, take off the four bolts on the fuel bowl. Remove the float and needle if needed!! The main jet uses a flat screw driver, take it off and put the 160 labeled main jet. Put everything back together and run it with a new plug. Run it at least 10 mins. Take it off and if it looks clean, then your still to lean go up to 165 and so on. But I don't think you will need to go big with simple mods. The color on the plug you are looking for is a nice brown or light black. I hope I helped I'm on my phone so bare with me here.
Old 06-01-2011, 05:47 PM
Bruce500's Avatar
Member #15599
thanks for having me aboard! and thanks those are helpful tips.. ill have to try the 160 i guess i though i would have to go higher than that but i could be wrong haha
Old 06-01-2011, 06:55 PM
Ruvalcaba's Avatar
Member #15578
Buy a nice ngk iridium plug to help burn everything smooth. Don't go a step colder yet
Old 06-02-2011, 10:49 AM
Bruce500's Avatar
Member #15599
A step colder in what?
Old 06-02-2011, 10:54 AM
Ruvalcaba's Avatar
Member #15578
on the plug!!! dont go a step colder yet. example if ur stock plug reads br6es, dont buy a br7es = step colder. wait till you really put some upgrades on ur quad.
Old 06-02-2011, 11:17 AM
Bruce500's Avatar
Member #15599
Oh and where can I get that plug at and what's the number for it for my pred 500?
Old 06-02-2011, 12:31 PM
Ruvalcaba's Avatar
Member #15578
Originally Posted by bruce500 View Post
oh and where can i get that plug at and what's the number for it for my pred 500?
ngk dcpr8eix
jetting polaris sportsman
what jetting should be on predator 500 with fmf pipe
what size jet does a predator 500 with fmf pipe need
Jetting an 05 Mclark Polaris Predator 5 01-20-2012 04:21 PM
can and jetting ? eswiger ATV Performance Modifications 4 04-06-2011 07:45 AM
Jetting Danco411 Polaris Scrambler 3 03-29-2011 04:14 PM
help with jetting nooner ATV General Discussion 3 05-07-2010 01:07 PM
Jetting chrisford4x4 Polaris Sportsman 11 01-17-2010 04:54 PM
