Old 06-05-2011, 04:38 PM
KaBoom's Avatar
Member #15642
Removing Home made lift kit from previous owner
So i got 00 500 with "hockey pucks" used for lifting. Only problem is buddy actually just installed them on the shock by compressing the spring. So in reality all he did was stiffen the front end up. Not lift it. I think he lifted the body(fenders and plastic) up a bit because the fender will not line up with the fuel on/off switch.
My question is this: What is the likelihood that the front shocks would go back to normal if i was to remove the pucks? Could i at least pull them back some way or would they spring back? I do not want to replace the shocks but they are beyond rigid atm.
Old 06-07-2011, 10:40 AM
KaBoom's Avatar
Member #15642
oic....
Old 06-13-2011, 04:57 PM
elmerkit's Avatar
Member #3805
You will be needing a lot of thinks and work on restoring to its original spec but it is do able.
Old 06-13-2011, 05:31 PM
Smoothbassman's Avatar
Member #2920
You can take the pucks out easy. If a body lift was done, you need to tear down all the plastics to see how that was accomplished. It might be some simple spacers in there to make it happen. It wouldn't be a big deal. You have to get the plastics off to tell though.
A good weekend project.
I had all of my plastics off of my 2011 XP in about 20 minutes. Had to do some modifications!!!
  • Polaris 3500 Winch
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
Old 06-14-2011, 04:04 AM
KaBoom's Avatar
Member #15642
Yea i did a lot of pre inspection and it is not very legitimate at all. It is indeed a front end body lift with 1 inch spacers on the floor panels. This in turn makes the plastic overlap the fuel shutoff valve making it near impossible to turn without removing it.
Tricky part about removing the plastic is that there is an aftermarket front bush guard with plow attachment. I have no idea how i can get the two bolts off that are holding on the plow plate. That should be interesting.
The thing that concerns me the most is the hockey pucks. They were installed on the bottom of the spring, not on the top of the shock where you would actually get a lift. Basically all these two pucks did was stiffen up the spring tension. I am wondering how probably it is that the springs will go back to normal if i cut the pucks out?
I took both front tires off last night and removed the hubs/bearings so i could get the 3 inch wheel spacers off. Did some inspection on the sway bar and steering column and it looks like i also need some new bushings so i will just replace those while i have everything off.
Old 06-14-2011, 08:53 AM
KaBoom's Avatar
Member #15642
Here is a pic of the shocks.
Old 06-14-2011, 09:18 AM
KaBoom's Avatar
Member #15642
Do you think if i remove those pucks the springs will go back to original compression?
Old 06-14-2011, 10:32 AM
Rickl1968's Avatar
Member #9087
I am not a mechanic but, i would think the springs would be weaker if the hockey pucks were on there for a while.
2011 Polaris 850 XP Orange Madness w/EPS, Camoplast 4S Track system, 3500# winch w/ Orange synthetic rope, front lock n ride storage box, rear composite rack. Extreme front and rear brushguards.
Old 06-15-2011, 03:55 PM
KaBoom's Avatar
Member #15642
Wouldnt the pucks be the equivalent of having the springs adjusted to max tension? So if i was to take out the pucks logically they should go back. I would hope...
Old 06-16-2011, 08:50 AM
Rickl1968's Avatar
Member #9087
That could depend on the weight of the previous driver and or how hard it was driven. Take a measurement from the ground, remove and remeasure. If not you could always put them back in until you can find new springs.
atv homemade lift kit
atv lift kit homemade
diy atv storage lift
home made lift kit for atv
homemade 3 inch lift atv pics
homemade atv lift
homemade atv lift kit
homemade atv lift kits
homemade atv snorkel polaris 850
homemade fourwheeler lift
homemade fourwheeler lift kit
homemade lift kit atv
homemade lift kit for a fourwheeler
homemade lift kit for atv
homemade polaris atv lift kit
homemade quad lift kit
homemade stuff polaris sportsman
how to lift an atv homemade
polaris homemade lift kit
polaris lift kit sportsman homemade front spring spacer
My XP 850 vs my previous Outlander 800's MN POPO ATV General Discussion 6 08-11-2011 09:04 AM
anyone have an audiopipe or a home made version? QuickSilver74 Polaris Sportsman 0 02-28-2011 04:41 AM
Need Help! With Home made snorkel loner_316 ATV Performance Modifications 2 10-22-2010 12:36 PM
Fender Guards..Home made... MUDDIE49 Polaris Sportsman 13 07-11-2010 11:54 AM
Home made lock and ride fimco sprayer with boom chuckraduenz ATV Visual & Body Modifications 6 06-20-2009 11:48 AM
