Old 06-13-2011, 10:12 PM
zach929's Avatar
Member #15970
Hard Wire From Voltage Regulator on 1999 Trail Boss 250cc
I am having charging problems on my 1999 Trail boss 250cc. I have recked two batterys now and I have bought a third and want to fix the problem. I checked ohms and appears stator is good, stator also has good AC voltage to it. I got a used but known to be good voltage regulator and replaced that. I have come to the conclusion that there may be a short in the ETC (Electronic Throttle Control) because I get approx. 13.8 volts on the red wire coming out of the voltage regulator at idle and as soon as I touch the throttle the voltage drops to around 5 volts. Then when the throttle is snapped back it it goes back to 13.8 volts. CAN THAT BE MY PROBLEM??
Also, Can I run the red wire from the voltage regulator directly to the pos. terminal of the battery, or to the starter solinoid positive right next to the battery or would that be a bad idea??
Thanks soooo much for any help I got alot of time into this so far and I am far enough where I dont want to quit without the problem fixed!
Tags
charging problem, etc short no batt chrg?, vr to battery?
1999 polaris regulator problem
1999 polaris trail boss 350 voltage regulator
2003 trail boss voltage regulator
4 wire atv voltage regulator
99 polaris voltage regulator
atv stator wiring voltage regulator
hard wired voltage regulator
how much voltage out of regulator on atv
how to wire a voltageregulater to starter
how to wire voltage on 250 cc
polaris atv voltage regulator
polaris atv voltage regulator problems
polaris stator problem 250
repair voltage regulator atv
trail boss 250 easy mods
trailboss 250 voltage regulator
voltage regulator for polaris 250
where is the starter on the 1999 polaris trail boss
Voltage Regulator Quantum673 ATV Repair and Maintenance 8 09-20-2011 08:46 AM
Voltage regulator Mcoffey24 ATV Repair and Maintenance 5 05-09-2011 03:06 PM
Wtb arctic cat voltage regulator tt425 ATV Parts for Sale 0 09-07-2010 01:24 PM
2003 Trail boss wire harness carkrazd ATV Repair and Maintenance 0 02-03-2010 07:10 AM
2004 trail boss wire harness carkrazd ATV Repair and Maintenance 1 08-31-2009 07:07 PM
