Old 06-13-2011, 10:23 PM
zach929's Avatar
Member #15970
1999 Trail Boss 250 ETC (Electronic Throttle Control) causing battery NOT to charge?
I have tested stator and it is good. Got a new Voltage Regulator. Bike puts out approx. 13.8 volts out of voltage regulator (red wire) at idle and as soon as I touch the throttle at all the voltage drops to around 5...The rpm's on the bike dont even change...thats how lightly I touch the throttle. Then the voltage bounces around a bit and I usually have to snap the throttle back to get it to idle and get the 13.8 volts.
Can I just twist the wires for the ETC together to bypass this feature? I do all the maintenence on this machine and I am the only rider. But I mostly just want to see if that could be my problem and then most likely replace it.
Also can I run the red wire out of the voltage regulator directly to the pos battery terminal? so I can rule out a short between the VR and the battery?
Old 06-14-2011, 05:16 AM
Old 06-14-2011, 08:19 AM
zach929's Avatar
Member #15970
Thanks. Man any help here is appreciated!
Should the voltage coming out of the voltage regulator be a constant voltage? This makes since to me but I am getting anywhere from 18 to 6 volts. But then when I hook the voltage regulator (red wire) back up again I see no flucuations. It is reading approx. 12.5 volts running and 12.8 volts off at the battery?
Old 06-14-2011, 09:26 AM
Manaen's Avatar
Member #6699
you should be able to bypass the ETC, just understand that you will now be able to do about 45mph in reverse. (not fun or safe)
I don't have the wiring diagram in front of me but I don't recall a connection between the charging circuit and the ETC. You may want to get a wiring diagram first and trace things down before you just ship on the ETC. Personally I would always rather fix it properly.
Lemme see if I have the diagram for your machine.
Old 06-14-2011, 11:35 AM
Manaen's Avatar
Member #6699
just checked my book and it only has wiring diagrams for 85 to 95. sorry
Tags
etc question
1999 polaris trail boss 250 wiring
1999 trail boss
1999 trailboss 250 is not charging
250 trail boss throttle
bypass etc polaris
bypass polaris etc
electronic throttle bypass
electronic throttle control polaris atv
ho do you adjust the electronic throttle control on a polaris trail boss 250
how do u hook up a voltage regulator on a polaris trailboss 250
how to bypass etc polaris
how to bypass the etc on a polaris
polaris 250 electronic throttle control
polaris atc etc
polaris electronic throttle control
polaris electronic throttle control bypass
polaris electronic throttle control troubleshooting
polaris etc
polaris trail boss electronic throttle control
wiring diagram 1999 polaris trail boss
2007 450 Sportsman Electronic Control Module lancemcdonald ATV Repair and Maintenance 3 03-22-2011 05:34 PM
So your trail boss lugs at mid throttle-try this 78dave ATV Repair and Maintenance 2 03-14-2011 02:20 AM
ETC polaris problems - Replacing Electronic Throttle Control PatDMania ATV Repair and Maintenance 2 12-20-2010 12:14 PM
'05 700 MV7 electronic throttle control problems ffehren ATV Repair and Maintenance 1 12-06-2010 05:26 PM
02 trail boss 325 battery placement? pafree ATV Repair and Maintenance 2 02-17-2010 05:08 AM
