Old 06-14-2011, 11:29 AM
Gilly's Avatar
Member #4344
850xp clutch removal
how do you get the secondary off an 09 850xp? Do you need a puller? Im putting on an EPI clutch kit and need to get the secondary off but am havin no luck. Anyone have there's off?
Old 06-14-2011, 06:56 PM
jrp's Avatar
jrp jrp is offline
Member #4745
you need the puller for the primary not the secondary. the primary is pressed on; the secondary is held on by a retaining bolt. remove the bolt and it will pull off, although its a bear to get leverage for pulling on it, due to the location. If you haven't removed the primary first, the belt tension can make the secondary even harder to pull off.
Jim
'10 850 XP EPS
Old 06-15-2011, 07:35 AM
Gilly's Avatar
Member #4344
thanks for the input. I got it off but what a challenge. Took a little prying and a little wiggling and a couple of beers! I never plan on taking it off again but i think a little anti seize will be applied.
2009 polaris 850xp clutch removal
850 xp clutch pictures
850 xp primary removal
850xp clutch alignment
clutch installation on polaris 850 xp
clutch instructions on 850xp
how remove clutch pulley from polaris850 xp
how to remove driven clutch on polaris 850
how to take polaris 850xp belt off
installing clutch on polaris 850xp detailed instructions
pictures of clutch istallation on 850 xp
polaris 850 secondary
polaris 850 xp clutch removal
polaris 850 xp ho clutch parts
polaris 850xp belt installation
polaris 850xp clutch disassembly
polaris forum 850 xp clutch removal
secondary clutch puller 850 xp
secondary drive clutch video 850 polaris
Clutch removal tools... swcheese ATV Repair and Maintenance 6 05-19-2011 12:33 PM
clutch removal tool WalterS ATV Repair and Maintenance 5 03-10-2011 08:19 AM
Clutch removal peterbilt ATV Repair and Maintenance 4 02-23-2011 03:42 AM
clutch removal 88TB250 ATV General Discussion 3 02-10-2010 07:24 AM
drive clutch removal wayne ATV New Members 3 05-18-2009 05:10 AM
