Old 06-16-2011, 04:35 PM
Bruce500's Avatar
Member #15599
jetting problem
I have a Predator 500 it come stock with a 150 main jet. I put a 160 in it and changed the needle that came with the kit. Everytime I start the quad as its idling its revving very high. I checked the idle screw and the fuel mixture screw so that's not the problem... Maybe I didn't do the needle right? Any suggestions?
Old 06-16-2011, 06:08 PM
elmerkit's Avatar
Member #3805
Did you adjust the af mixture screw afterwards?
Old 06-16-2011, 06:17 PM
Bruce500's Avatar
Member #15599
Yes, I'm thinking my throttle is stuck or something because I didn't disconnect it and there was a lot of tension on it by turning the carb around
06 polaris 500 predator jetting
best jetting 06 polaris predator 500
predator 500 jetting
Jetting an 05 Mclark Polaris Predator 5 01-20-2012 04:21 PM
can and jetting ? eswiger ATV Performance Modifications 4 04-06-2011 07:45 AM
Jetting Danco411 Polaris Scrambler 3 03-29-2011 04:14 PM
help with jetting nooner ATV General Discussion 3 05-07-2010 01:07 PM
Jetting chrisford4x4 Polaris Sportsman 11 01-17-2010 04:54 PM
