Old 06-25-2011, 04:40 AM
Pamiller450's Avatar
Member #16276
2009 850xp eps ?
I have been working a friends xp and I have a few questions.
So far it has a 3in highlifter lift, rad relocate, snorkels, 31 laws skinny wide combo with 14x7 in rims.
After snorkeling I noticed it runs rich what is the best programmer available for these things.
This thing will weelie very easily in high does it need a clutch kit and what would the best kit be.
On his dash on the left side the middle light I on what is this light. I can push the select button until it flashes and it gives some sort of code I think.
Old 06-25-2011, 05:50 AM
Old 06-27-2011, 09:47 AM
Member #16276
So no one on this Polaris site knows anything about a Polaris. looks like I came to the right place for answers.
Old 06-27-2011, 10:46 AM
Action's Avatar
Member #14212
If you go to the Polaris website you can download the owners manual which will tell you what the light is and what the code means.
Action
2011 850 XP EPS Camo
A Arm Guards F&R
F&R Storage box
GBC Dirt Commanders
ATV Guru Brush Guard F&R
Ricochet Skid Plates
UNI Air Filter
Old 07-28-2011, 05:19 PM
madmathew's Avatar
Member #16744
That should be the EPS light which means there is a problem with the EPS.
Old 07-31-2011, 05:22 AM
lost cause's Avatar
Member #9763
^^Wow 2nd post. that is a good way to get people to help you out.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 08-07-2011, 03:08 PM
sony420's Avatar
Member #12986
Warning light
More than likely you are getting a error with the eps. If you push the "sel" button on the speedo you will get a error code. Probably 520230 31. Which means you have to take it to Polaris dealer and have them reflash the ecu. They are doing mine right now. They told me there is an update for the power steering, and that reflashing it will take care of it(fingers crossed). The reason for the error code is usually something like a dead or weak battery, a voltage spike or charging the battery when it's on the machine..a big no-no from what I read. Good luck.
2010 polaris 850 power steering light flashing
2010 polaris 850 spotsman engine light code 520230
2011 850 xp eps service manual
520230 fault code polaris
520230 polaris
520230 polaris sportsman
850 xp eps light
polaris 520230 31 code
polaris 850 xp eps light
polaris 850 xp eps light on
polaris 850 xp power steering code 520230
polaris 850xp eps light
polaris atv eps problems
polaris atv error code 520230
polaris error code 520230
polaris sportsman 850 snorkel
reflashing polaris 850 xp
2009 850xp no power!!! Thompy ATV Repair and Maintenance 1 04-04-2011 03:48 PM
Oil in air box 2009 850XP Polaris Bear Polaris XP 3 01-17-2011 07:12 PM
New here- 2009 850xp problems highcountry1 ATV General Discussion 6 09-14-2010 05:15 AM
ITP/Maxxis 15"ers on 2009 850Xp Volt ATV Wheels & Tires 5 03-26-2010 11:52 AM
2009 850xp LE production numbers tylermoore Polaris XP 1 02-21-2010 02:47 AM
