Old 06-25-2011, 04:20 PM
RKMHD's Avatar
Member #3450
Sons Modded Scrambler 50 is having problems
We have an 02 50cc. with an AAEN speed kit on it. basically a pipe, oil block off, and a cone filter, I'm sure there is a jet kit of some sort in it. I had to change the clutch back to stock. It was way to much for him.
The problems we are having is starting. When I get it started it runs for a little bit then cuts off. It has sat for quite some time.
I pulled the carb and took it appart. I found a bunch of green flake in the bowl. I took it all appart. and blew air in all the holes. I counted the turns on one of the srews. there is another small screw by the opening of the carb that the filter ataches to. I didn't pay attention to that one when I pulled it out. I'm not sure if it was tight or set at a certain depth.
I got it started and it ran for a little bit then started to stall out. I reached down and covered part of the carb and it started to run better.
Is there anyone out there that works on these little carbs that could give me some pointers?
Thanks. It is a Muniki carb...
Old 06-25-2011, 04:42 PM
RKMHD's Avatar
Member #3450
a little update. It seems that if I choke it with the palm of my hand I can start it easier and keep it running.
The screw on the side that I counted the turns on was only the idle screw.... I am not sure what the other screw was at the mouth of the carb. It was long and had a spring on it. I wish I could find a diagram of this carb that tells you how it works and what the normal settings are.
Old 06-25-2011, 05:01 PM
Old 06-26-2011, 04:17 PM
twoulfe's Avatar
Member #15438
turn it clockwise till it seats but to tight then back it off 1 and 1/2 turns. i dont know about this specific carb but thats a good starting point for any carb. hope it helps
Old 06-26-2011, 05:23 PM
RKMHD's Avatar
Member #3450
I pulled it back off today. I was able to get it to stop leaking. I pulled the reeds as well to look at them. They look fine. However I don't know what they should look like anyway.
I still get it to run. I am about 1 1/2 turns out. It just starts to bog out when you give it gas. As soon as I put my hand over the Carb it starts acting correctly. I can actually drive it around like that. Could this have something to do with my elect. choke???
2000 polaris 50 trouble in the carberator starting it
2000 polaris scramber 50 choke
2000 polaris scrambler 50
2000 polaris scrambler 50 troubleshoot
2000 polaris scrambler 50cc
manual choke scrambler 50
polaris scrambler 50 carb adjustment
polaris scrambler 50 carb problems
polaris scrambler 50 carburetor
polaris scrambler 50 carburetor problem
polaris scrambler 50 choke
polaris scrambler 50 manual choke
polaris scrambler 50 mods
polaris scrambler 50 only runs on choke
polaris scrambler 50 owners manual
polaris scrambler 50 owners manual 2000 oil fill
polaris scrambler 50 performance
polaris scrambler 50 performance parts
scrambler 50 choke
scrambler 50 mods
My Youngest Sons First Ride Bait ATV Media 9 06-16-2011 10:38 PM
modded 2000 scrambler did i get a deal coreyusmc Polaris Scrambler 3 02-20-2011 09:52 AM
scrambler problems please help! 97polaris500 Polaris Scrambler 13 02-07-2011 07:16 PM
Sons First Deer spongecop ATV Media 16 01-07-2011 03:02 AM
scrambler problems... jehunter870 Polaris Scrambler 3 11-18-2009 03:24 AM
