06-28-2011, 10:16 PM
Member #15018
Snow plow options
Does anyone have a suggestion on a snow plow? Make? Model, Brand? i know it's a little early, has anyone ever tried to plow gravel/dirt? if so how did it hold up?
06-29-2011, 03:19 AM
Member #16252
I just got my X2 a couple weeks ago, I haven't got my plow yet, but I've done quite a bit of research and will probably get the Moose Utilities 60" "County" Plow. The Polaris Glacier plows seem pretty good too.
1998 Xplorer 300-Stock
06-29-2011, 06:34 PM
Member #3805
You might want to consider Warn Pro Vantage editions
06-29-2011, 07:23 PM
Never too early! Last winter all the plows where out of stock because of all the snow storms. Remember the early bird gets the morning worm. We have tested both Warn & American. They are the strongest on the market. Any questions feel free to call the shop and ask for me.
06-30-2011, 07:21 AM
Member #16069
My father has a 2005 sportsman 500ho with the glacier 1 plow system and he uses his to fill in graves at the cemetary he works for on a regular basis, and he plows alot of snow with it in the winter months his only complaint is that he wishes the plow had a little more wieght to it so it wouldn't ride up so often. He says the main thing is to remember you are using an atv with a blade not a D8 dozer so only push a small amount at a time. I have used my 2010 sportsman 500ho with the glacier 2 system for snow all last winter here in northwest NY and it worked great. I did use it a few weeks ago to spread a couple loads of sand for my neighbors pool and it pushed quite easy. They are great work horses.
07-01-2011, 04:28 PM
Member #5044
I have the glaciel II plow on 2010 550 touring and it sucks.The plow frame rubs and blade is to light. There is a glaciel III out now I hope it is better.
07-01-2011, 04:31 PM
Don't make the same mistake twice! Get a Warn or eagle.
07-01-2011, 05:26 PM
Member #11247
I have a G3. Don't get it. It works great for me, but the quality is not impressive. You might as well go with another brand for the price. I will next time now that I know. It just feels like the G3 is made to the minimum requirements for the job.
Sent from my SCH-I510 using Tapatalk
2011 Trail Boss - HIDs SOLD
07-02-2011, 06:33 PM
Member #10159
I have an old Polaris plow and it will work on gravel & dirt if you take your time. It doesn't raise high enough so I wouldn't recommend it today, even though it is well built. I'm sure there are much better designs now. I'd call Thor and trust his input if I were in the market now.
2011 Sportsman Touring 850  (current)
2006 Outlander 400 (Sold)
2001 Sportsman 500HO (Current)
1997 Explorer 500 (Traded)
1998 Sport 400. (Sold)
1994 Trailblazer. (Sold)
198? Suzuki Quadsport 230. (Sold)
197? Yamaha YZ225 Three-Wheeler (Traded)
07-04-2011, 08:16 AM
Member #12318
I got the Warn front mount system last winter and man is it awesome! Real heavy duty, easy on, easy off. Highly recommended.
2011 polaris sportsman 550 x2 snow plow, 60 polaris glacier snowplow for a 2005, curent price for snow blade to fit 07 polais sportsman, how high do blades for polaris x2, plows for polaris x2 atv, polaris 2010 550 snow blades, polaris 550 x2 snow, polaris atv snow plow, polaris county plow, polaris glacier snow plow sportsman, polaris snow plow systems, polaris x2 glacier plow system, polaris x2 plow, polaris x2 plowing snow, polaris xplorer 400 for plowing, price on snow plow for 2005 polaris sportsman, snow plow for 2011 polaris sportsmam 550, warn vs glacier snow plow, will a polaris 400 plow good, will plow fit polaris explorer or sportsman
