Old 06-29-2011, 05:18 PM
mjscharlotte's Avatar
Member #8559
Do new tires have to = clutch kit??
Hey everyone,
I have a 2010 XP 850 with EPS and just bought 27" ITP Mudlites. I had the dealer do the first service and mount the tires. I picked it up yesterday and right away the dealer told me to get a clutch kit before I ripped the rear end out of the machine. I do mostly trail riding but don't want to have any nightmare stories of the rear end getting torn up. Do I really need to have a clutch kit installed or is the dealer just wanting me to spend $$$. Thanks for any suggestions. BTW - I went with 27"/12/14 in the rear and 27"/10/14 upfront. Looks awesome!!
Old 07-20-2011, 10:14 AM
rodeo1's Avatar
Member #15389
depends on what you are going to do for riding, but my opinion is that you should be good to go with out.
if you play in thick sticky mud it won't hurt to have more low end, but i don't think you will need it. just my 2 cents.
Old 07-20-2011, 12:32 PM
cwlongshot's Avatar
I agree, the stock size is 26". So unless your tire is very heavy or excessively aggressive. You should be just fine.
The clutching in the XPs is much better than previous models.
Old 07-20-2011, 01:06 PM
catmando31's Avatar
Member #12802
had 27" mud trax on 14" wheels since the day i bought my 08 800.3 years next month ,no belt or clutch issues.by the way where do you ride?i have been to CAW in s.c. about 1 hour south of charlotte really cool place!
2008 honda 700xx grey and black. 2008 mossy oak sportsman 800 H.O. 27" MUD TRAX TIRES on 14" sti wheels,3000 lb gorilla(promark) winch,front and rear PURE POLARIS brush guards.
Old 07-20-2011, 01:23 PM
jrp's Avatar
jrp jrp is offline
Member #4745
I agree, for typical trail riding below 4000 ft it will be fine. Just be aware that those larger, heavier tires do eat up some of your low end power and when you're in mud, sand, on a steep hill, or travel to the mountains above 6000 ft, you may need to adjust when you would use low instead of high gear to prevent excess belt slipping.
Jim
'10 850 XP EPS
Old 07-22-2011, 11:57 AM
lost cause's Avatar
Member #9763
You will be fine with those tires without clutching. Especially if you are just trail riding. Just remember that even with stock tires you should put the bike in low gear when towing or stuck in the mud. I ride only mud and have one of the most aggressive tires you can buy (29.5 outlaws), and still have stock clutching. Just knowing when to use low gear will keep you out of trouble.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
clutching polaris sportsman for bigger tires
do i need a clutch kit polaris sportsman 800 27
do i need a clutch kit with 26 tires polaris
do you need a atv clutch kit with bigger tires
does an atv need a clutch kit with bigger tires
gorilla axels on 2011 polaris 850 xps
heavier tires on lower powered atv
how big of a tire on my atv can i use before i need new clutch
how heavy can i go with aftermarket tires before i need a clutch kit?
how much larger tire requires clutch kit
if i have bigger tires on my atv do i need a clutch kit
polaris 850 tire upgrade clutch kit
sportsman 800 clutch springs bigger tires
trailboss 325 bigger tires
what does a clutch kit do for a atv
what will a clutch kit do for my atv
what will a clutch kit for my polaris sportsmen do for me
when does an atv need a clutch kit
will bigger tires on a quad reduce low end torque
Mudder Clutch with stock tires mckishen EPI Performance 3 08-19-2011 10:58 AM
Do new tires have to = clutch kit?? mjscharlotte ATV Performance Modifications 8 08-09-2011 11:43 AM
having clutch problems wonder if its due to big tires or clutch wear HELP johnnypolaris500ho ATV Wheels & Tires 8 04-03-2011 07:17 PM
changing clutch springs for larger tires QuickSilver74 Polaris Sportsman 5 12-29-2010 07:38 PM
Clutch Kit for Larger tires t2timmy Polaris Sportsman 7 08-26-2009 01:22 PM
