Old 07-04-2011, 08:09 AM
800touring's Avatar
Member #14149
bigger charging system
hey i was wondering how i can get a bigger charging system or alternator to put off more watts or amps on my polaris 850xp to run more stuff.
Old 07-04-2011, 09:56 AM
How much stuff are you running? The stock stator is only about half used up. There is plenty of room for lights, heated grips/gear, GPS, etc.
There are a couple companies that rewind stators, and that could be an option. Prob cheaper to have yours rewound then to buy a new one.
Old 07-04-2011, 11:15 AM
800touring's Avatar
Member #14149
i have a 200 watt atv audio pipe and i am always useing that when ridin. Normaly dont have lites turned on besides at nite and i turn off the sterio when i use my winch and i have piaa front brush gard lites and then my stock lites and thats all i have on it but i just whanted somthing that could run more power on the quad because I am whant to add more led lites on the quad that are another 150 watts and then mabe a few more things. My owners manule said the quad puts out 630 watts at 3000 rpms and thats as high as it gose
Old 07-04-2011, 11:28 AM
Ha! you are running quite a bit. Okay, I will let you be. Usually people who think they need bigger stators are really far from it, so I was just testing you. Sounds like you know what you need.
I dont have a lot of help here, other then I would try to get in contact with Ricky Stator (Ricky Stator) and see if they can help you.
Also I have found, that sometimes the best work are the guys who can do this kind of work local. Your local shops should know if there is anyone capable in you area of doing this.
Old 07-04-2011, 11:34 AM
800touring's Avatar
Member #14149
ya thanks for the info on that ya I kinda new what i was doin thanks for the help tho.
Old 07-04-2011, 11:47 AM
Not many people do! Ill look around more, If I find some better options, I post them here. Otherwise, let us know what you find/do, please
Old 07-04-2011, 11:52 AM
800touring's Avatar
Member #14149
ok I will. hey and also do u no if there is a back up starter u can get for the 850s?
Old 07-04-2011, 05:58 PM
elmerkit's Avatar
Member #3805
Would you consider adding another battery for all the electrical stuff you have you can try adding a capacitor on your charging unit.
Old 07-05-2011, 03:22 PM
800touring's Avatar
Member #14149
ya that is what i am going to have to do
add on atv charging system
aftermarket polaris charging system problem
atv charging system
1989 Trail Boss charging system wtrlvr43 ATV Repair and Maintenance 1 03-30-2011 08:36 PM
Charging System - Problem Identified - Looking for Solution KBarton ATV Repair and Maintenance 0 01-30-2011 05:57 PM
Sportsman 90 charging system Tim Bell ATV Repair and Maintenance 5 10-08-2010 08:45 AM
Sportsman 90 charging system Tim Bell ATV New Members 1 09-28-2010 04:24 PM
1997 Polaris Xpress 300 Charging System Nandy Polaris Sportsman 1 09-05-2010 04:22 PM
