Old 07-04-2011, 01:03 PM
masoman95's Avatar
Member #14304
2008 Sportsman 300
hello, my sportman 300's fuel indicator is not working and is most likely stuck. it is not electronic and i was wondering if i could somehow get it out of the fitting and replace it thanks
this is what im talking about
Part Number 10
http://parts.polarisind.com/Assemblies.asp
Old 07-04-2011, 04:24 PM
ffjb154's Avatar
Member #15696
The same thing happened to mine. Take the gas cap off and pop the black plastic off the top of the tank. You can grab the gauge and twist it out with your hand. On mine, the two rods that hold the float came out of the gauge. I used a rod with a magnet and fished out the assembly. Do the same with the float with a piece of wire. I used some adhesive that was gas resistant and glued them back in. Make sure you got the float lined up properly so it will show full when full. Hope this helps. JB
Old 07-04-2011, 05:16 PM
masoman95's Avatar
Member #14304
Thanks alot, I'll try it when I get the time. And just a random question, did your speedometer happen to stop working too? Cause mine did lol thanks.
Old 07-04-2011, 05:48 PM
masoman95's Avatar
Member #14304
And what do you twist off? The whole thing or just the part where it tells the gas?
Old 07-04-2011, 10:56 PM
ffjb154's Avatar
Member #15696
The gauge is black and the tank is red. Grab a hold of the plack part at the base and wiggle it side to side as your pulling up. It's on there pretty good but will eventually come out. The rest of float assembly will be inside the tank if it came apart like mine did. The two metal rods are hot pressed into the plastic gauge and have vibrated out over time.
Old 07-05-2011, 06:17 PM
masoman95's Avatar
Member #14304
thanks everyone, and the 2 rods and float did fall off, so i used the magnet to fish it out put it back together with a little silicone where they go in and works good! now on to my next minor problem, my speedometer bummed out lol im ordering a new one and hopefully that works! thanks again
08 polaris sportsman 300 wiring
2008 300polaris
2008 polaris sportsman 300 atv
2008 polaris sportsman 300 price
2008 polaris sportsman 300 problems
2008 sportsman 300 aftermarket parts
assesbly of a 2008 polaris 300 atv
polaris atv 300 2008
polaris sportsman 300 modded
polaris sportsman 300 performance
polaris sportsman 300 used
problems with 2008 polaris 300 sportsman
sportsman 300 plastics
2008 Sportsman, what is this? Maineiac Polaris Sportsman 19 05-21-2011 08:00 AM
2008 sportsman 400 HO killemkc ATV Brakes & Suspension 4 03-09-2011 07:32 PM
2008 500 Sportsman ZR 900 ATV Repair and Maintenance 11 02-04-2011 08:58 AM
2008 Sportsman 500 what do you think? ispperformance ATV Purchasing and Price 3 01-30-2011 02:43 AM
2008 Sportsman 400 ho chris01 ATV Repair and Maintenance 1 07-13-2009 08:17 PM
