Old 07-10-2011, 06:26 PM
doworkdiesel's Avatar
Member #16678
2010 850 2" lift bigger tires exhaust tuner new to forum
ey new to the forum i have a 2010 850 wanting to do a 2" lift bigger tires exhaust and maybe a efi tuner
im looking for info like who has a good lift kit how big of tires can i run with the lift and when do i need to update the drivetrain when the tires get to big
looking for a good tire i do mostly road riding so dont want alot of tire shake but when i get in mud i dont want to be left sitting good all around tire how tall and wide tire can i go with the lift wanting to get the diesel spoked rims
who has a good exhaust looking for power dont want annoying load
do these efi make a difference or should i just run it on the rollers and get it custom tunned
thanks
Old 07-10-2011, 08:43 PM
Old 07-25-2011, 09:41 AM
lost cause's Avatar
Member #9763
Welcome. The lift is pretty common. Most are pretty much the same but I would stick with the proven names like Rubber Down Customs, Highlifter, SuperATV, Gorilla, or Catvos for the lift. I like my Rubber Down Customs on my 800. With the lift you will be able to fit 32's if you wanted. As far as tire choices, if you ride the road a lot you will not be happy with something that does well in mud because it will wear out quickly on the road. Drive train issues usually just happen with pure mud tires and a heavy thumb, but any time you add a lift and change the angle of the stock axles you will eventually be replacing axles. As far as aftermarket exhausts, all are annoying to me. I have wasted my money on them before and have returned them to stock. Not enough of a power difference to deal with not being able to hear yourself think.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
2010 polaris 800 hd bigger tires
bigger tires polaris 850 problem
good lift and tires for a 850
good lookin polaris 850
how big tires can i fit on polaris 850
pictures from hatfield mccoy trailfest 2011
polaris 850 pictures big tires
polaris 850 with big tires
polaris tuner
rubber down lift
what tuner on a polaris sportsman
HD front spring and 1.5"-2" rear lift Combo kool_500HO ATV Brakes & Suspension 15 05-27-2011 12:13 PM
6" Lift, 30" Tires - PROBLEMS??? Hunt@r07 Polaris Sportsman 1 05-19-2011 05:11 AM
Aluminum 14" wheels/tires 2010 850 xp eps ARTxSCIENCE ATV Parts for Sale 2 04-08-2011 09:41 PM
2010 Polaris 850 XP W/ Pitbull Rocker tires in 12" of snow michael1871 ATV Media 17 02-25-2011 06:23 PM
2" lift kit for the 2010 850 xp XTRM-HNTR ATV Brakes & Suspension 4 03-18-2010 06:42 PM
