Old 07-11-2011, 07:04 PM
tjack's Avatar
Member #16706
Unhappy grinding when shifting and stalls when pressing the throttle
i just got a 1995 polaris 250 trail boss. when i press the throttle the engine stalls. i have to balance the choke and throtle out to keep from stalling. also, when i go to shift into forward or reverse there is a grinding noise and it does not want to engage. does anyone know how to adress these issues?
Thank you
travis from tomah, wi
Old 07-13-2011, 12:34 PM
tjack's Avatar
Member #16706
i fixed the grinding problem but i still have a problem with stalling when i press the throttle please help!!!!
thanks
travis from tomah
Old 07-13-2011, 05:16 PM
elmerkit's Avatar
Member #3805
Your fuel system might need some cleaning like your carb.
Old 07-13-2011, 05:52 PM
tjack's Avatar
Member #16706
okay i will do that tomorrow thanks! and also my gear oil in my gear case is leaking i dont really know where it is coming from though so help plzzz thanks!
Old 07-25-2011, 04:28 PM
kajun's Avatar
Member #4372
What did you do to fix the tranny issue.
Old 08-21-2011, 08:04 AM
dnocash1's Avatar
Member #17901
yes how did you fix it???
Old 08-21-2011, 08:42 AM
sfrasher's Avatar
Member #13967
I found where the OP (tjack) answered someone else!!
"i would put some gear fluid in the gearcase... fill it up to the bottom of the fill hole make sure you do not fill past the threads in the fill hole. hope it works."
The next poster (chopperbill) said "The belt and pulleys are probably grungy from use and causing the driven pulley to turn at idle. Take the belt off and clean it and clean the pulleys. Or your idle is set to high. Or it has the wrong belt on it."
trouble getting into gear (grinding) 350L
I am having the same grinding problem, but it started when my carburetor got fouled. I think it was because I had to keep the idle way up, so once I get my carb cleaned right and back on, my problem may go away.
Spence
2001 Trail Boss 325, AA model, since April 2011
"I've been sane, and I've been crazy. Crazy is more fun!"
Tags
1995, 250, polaris, stalling, trail boss
250 polaris 4 wheeler will go in reverse but not forward
4 wheeler grindes into gear?
95 polaris 250 trail boss wont go forward
95 trailboss 250 grinds while shifting
four wheeler not going into gear grinding
four wheeler stall when i put it in reverse
my fourwheeler keeps stalling out
polaris 250 grinding noise
polaris 250 stalls in reverse
polaris 250 trail boss wont shift
polaris 325 trail boss idles but dies
polaris atv when push on throttle it dies
polaris stalls throttle
polaris trail boss keeps stalling
polaris trail boss wont go in gear
why does my 250 trail boss stall
why does my 4 wheeler stall in drive
why does my 4 wheeler stall when i put it in gear
why does my four wheeler grind when putting into gear
why does polaris stall
HELP! Sportsman 500 stalls when shifting from neutral to high and neutral to reverse. dt31906 ATV Repair and Maintenance 4 06-04-2011 08:52 AM
Scrambler stalls at full throttle xdarkenagex Polaris Scrambler 11 04-17-2011 06:13 PM
Grinding when shifting into gear lj-rubi ATV Repair and Maintenance 6 08-27-2010 10:46 AM
Twist throttle vs. thumb throttle? rsmith0801 Polaris Predator 5 03-22-2010 05:11 PM
Thumb Throttle VS Twist Grip Throttle Billster1955 Around The Garage 12 01-27-2010 07:54 PM
