Video cameras - Page 3 - Polaris ATV Forum
post #21 of 35 (permalink) Old 08-23-2011, 04:09 PM Thread Starter
cwlongshot's Avatar
Wink
Originally Posted by bgirard420 View Post
sound quality is good too!
This is what I like best about it! The EPIC was aweful!! For the $$ I just may have to have one too!
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
cwlongshot is offline
post #22 of 35 (permalink) Old 08-23-2011, 05:47 PM
850trailrider's Avatar
video camera mount
made one for the lock and ride for my Gopro 1/4 thick pc alluminum scrap ground to shape and screwed into factory screw hole in box used 3 m mount that came with camera srayed with bedliner paint locks in nicely and able to keep an eye on it easier to operate than on helmet and provides cool view overfront
ID:	4024   Click image for larger version
ID:	4025   Click image for larger version
850trailrider is offline
post #23 of 35 (permalink) Old 08-24-2011, 03:49 AM Thread Starter
cwlongshot's Avatar
Wink
Looks great 850 TR!! I also like the footage filmed from this position!
Here is a really good comparison between the Epic and Midland.
These two clips where shot at same time. Under same lighting from same position on right side of handle bars. The Midland is on a 4" piece of 1/4x20 threaded rod. The Epic in a 1/16" flat steel mount. Both quite rigid.
The first is the Midland second Epic.
Here is pops Midland:
Check out this video on YouTube:
This is from my leade machine filmed with the Epic:
Sent from my iPhone
Lock N Ride roof
LOTS more coming...
post #24 of 35 (permalink) Old 09-08-2011, 09:18 AM
guruerror's Avatar
I'm not knocking other cameras...but I would vote for the GoPro HD. I've been using one in my truck for a year or more and the quality and frame rate are GREAT. I just ordered another case so I can mount it on the bike. I'm just stuck deciding 'where' to put it.
My first thought was on the front in the little spot next to the winch. I figured that this would give it better protection from branches and brush, BUT I couldn't resist ordering the LCD 'BacPac' attachment too. Admittedly it would be pretty cool/convenient to be able to see what your shooting while out and about, so, if I use the BacPac I'll probably go for a handle-bar/pod mount...dunno. That's my weekend project, I'm sure I'll figure something out.
The only issue I can think of with the GoPro is that it can be a little finicky about memory cards. I use a Patriot 32GB SDHC and haven't had a single problem. They've posted recommendations on SD cards on their support site (Frequently Asked Questions About GoPro HD HERO Camera & Accessories) stick with a name brand and you'll be fine.
Also, make sure you have the latest firmware update for your camera (GoPro Customer Support - Contact Us for Knowledge & Instruction) as they always seem to add new features with each new release.
CNTRY
DTOM
guruerror is offline
post #25 of 35 (permalink) Old 09-08-2011, 07:26 PM
Phil030's Avatar
I finally made it out on the Sportsman with my Contour HD. It came with a helmet mount that uses the goggle strap (which I like for smoother video). The lasers that shine out the front to help with alignment are a nice feature, and the large sliding "record" switch leaves no doubt that you are catching the action. The only down side compared to the GoPro is the narrower field of view (135 degrees verses 171, I think). Again this video is shot at 640 X 480 to save memory. So far I am very happy with this camera!
Phil030 is offline
post #26 of 35 (permalink) Old 09-14-2011, 09:11 AM
guruerror's Avatar
I did some test runs with the GoPro this weekend to figure out where to mount it...I ended up going with my first thought, next to the winch.
CNTRY
DTOM
post #27 of 35 (permalink) Old 09-14-2011, 01:54 PM Thread Starter
cwlongshot's Avatar
Yes the GOPRO is the one to get... We will see how the funds are when the time comes. I have been watching EBay.
Lock N Ride roof
LOTS more coming...
post #28 of 35 (permalink) Old 10-25-2011, 10:11 PM
Bucket's Avatar
I used the contour today, 170 field of vision easy to set up and you can view it from your android via bluetooth, when i downloaded the video for editing i couldnt believe the quality of the video,(it was far better than even I thought it would be) i got a buddy rolling with the gopro...good cam great video aswell but the contour was much easier to use, easier to site in and easier to view while setting it up, for me its hands down...Contour, the thing even comes with an internal and external mic hook up on a lapel mic.( and the audio was great).
Bucket is offline
post #29 of 35 (permalink) Old 10-27-2011, 08:17 PM
Phil030's Avatar
The following is a video made using one ContourHD and two GoPro cameras.
The RZR has a GoPro, as well as the the one mounted on top of the helmet. The side mounted cam is the Contour.
Of the three, the GoPro in the RZR seems to have the best picture. I think that is at least partly due to the location it is mounted (out of the sun and dust). It is worth noting that due to a small memory card (2Gb), the Contour footage was filmed at a resolution of 640 X 480.
Either way, I don't think you can go wrong with either camera.
Phil030 is offline
post #30 of 35 (permalink) Old 10-28-2011, 05:05 PM
bgirard420's Avatar
Great video Phil! I liked the way you combined the footage so it flows like a motion picture. Like when the guy on the can-am is stuck, you see it from afar, then his perspective, then afar again. Good tunes never hurt either.
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
bgirard420 is offline
July 3rd video UnityH8r ATV Media 8 07-16-2011 09:03 AM
ATV Maintenance Video's jayhkr ATV General Discussion 4 03-10-2011 02:04 AM
My first video bukaty ATV Media 4 02-28-2011 11:26 PM
Video in my new 850 ZEUS ATV General Discussion 4 09-23-2010 06:00 AM
ATV Video Sites yellow2003xtreme ATV Media 4 05-04-2010 06:24 PM
