I have one wired on my Dodge truck(being able to turn it on manually makes the AC work better in traffic). Being able to turn it on manually is nice on an ATV so if your factory temperature sender or switch goes bad far from home, you can still turn the cooling fan on manually. The way most of the single pole ON-OFF-ON switches are setup, the middle position would have to be automatic, and up would have to be on, and down would have to off. You're better off going with 2 separate toggle switches, it will make wiring alot easier if thats what you want to do.
1998 Xplorer 300-Stock
