You need other mods to supplement it, otherwise it does nothing. It would go with an exhaust system, airbox mods, or engine mods. Some type of mod that would require the machine to need more fuel. Then, when installed, it piggybacks on the EFI system, and allows you to change the signal for the amount of fuel the injectors should use, thus, allowing you to have these mods, and get the machine running at the proper A/F ratio, much like if you were rejetting a carb after similiar mods.
