Old 08-04-2011, 09:44 AM
scott_r's Avatar
Member #16383
snorkel install
Is this a huge mod to do in terms of time? Im thinking of getting this done on my Sportsman 800 but my worries are the shop time at $90 per hour. Do most guys do this themselves?
Cheers!!
Old 08-04-2011, 11:53 AM
racer37l's Avatar
Member #5629
You are right that most do add this mod themselves. You'll find several threads on this subject. Just do a search and you should find what you need.
Oh, if you find one by Corndwg1, his thread will give you all the things you need and show you how to do it!
Good luck!!
Con
Old 08-04-2011, 12:24 PM
scott_r's Avatar
Member #16383
Whats the best kit with instructions to buy for an Sportsman 800 EFI?
I could not find this user, Corndwg1 is this the correct user name?
Cheers!!
Old 08-04-2011, 12:53 PM
Tkdakota's Avatar
Member #16865
Snorkelyouratv.com
That's what I have for my 2010 800 efi. It has very detailed instructions. I haven't installed it yet but my buddy has one of their kits and it was very nice.
Old 08-04-2011, 06:39 PM
racer37l's Avatar
Member #5629
Sorry, I got his name wrong.
If you go to Rubberdowncustoms.com forum, then go to the Polaris section and look thru the sticky section you will find it(CornDwg01 how to's).
I'm not good at posting links yet, so hope this helps!!
Con
Old 08-05-2011, 05:52 AM
lost cause's Avatar
Member #9763
Or give Triangle ATV a call and order one of thier stealth kits. It was worth the money in my opinion. No one can even tell that my bike is snorkeled and I love it. Well thought out kit that comes with everything you need to snorkle the air and belt intake, belt exhaust, and all the vent lines. Comes with an instructional DVD as well.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 08-05-2011, 03:35 PM
tekrsq's Avatar
Member #6432
Pics ???
08 Sportsman 800 Touring- 2500lb Polaris winch, front & rear brush guards, front rack extender, headlight Mod, Quadovator temp gauge, RAC Engineering reverse/ work lights, Polaris rear storage box
05 Scrambler 500 (wife's bike)- Polaris rear rack, Bear Claw tires
Old 08-06-2011, 12:29 PM
lost cause's Avatar
Member #9763
For your viewing pleasure.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
Old 08-06-2011, 06:19 PM
racer37l's Avatar
Member #5629
Looks good lost cause!
Did you turn your belt exhaust down in the pod?
Do you see any dust getting in the air intakes from the belt exhaust?
Con
Old 08-06-2011, 07:16 PM
messinaround's Avatar
Member #2198
Here is what I did with mine worked awsome and could still use the box
2010 polaris sportsman 500 snorkel pictures
2011 polaris sportsman 800 how to snorkel air box
atv snorkel kit intake
help installing polaris sportsman snorkel
polaris lifted with snorkel atv
polaris sportsman 700 gorilla lift
polaris sportsman 800 lift images
polaris sportsman 800 pod snorkel
polaris sportsman 800 pod snorkel#gsc.tab
polaris sportsman pod snorkel
snork per quad polaris scrambler
snorkei kits polaris 500
snorkel 4 scrambler quad
sportsman 700 snorkel
sportsman 800 snorkel kit
triangle atv
triangle atv snorkel
triangle atv stealth snorkel
triangle atv stealth snorkel directions
triangle snorkel sportsman
Problems after Snorkel install on Polaris 800 Frisky Dingo ATV Performance Modifications 4 05-07-2011 09:49 AM
Problems after Snorkel install on Polaris 800 Frisky Dingo Polaris Sportsman 6 05-07-2011 09:42 AM
Snorkel Kit xtolled ATV Performance Modifications 0 05-03-2011 01:26 AM
Snorkel Kit ssgtos ATV Parts for Sale 4 09-21-2010 07:57 AM
550 Snorkel Kit? mals_motorman44 ATV New Members 4 09-02-2010 04:49 PM
