08-06-2011, 03:18 PM
Member #6432
Scrambler 12v accessory wires
Does anyone know if (and where) there are any 12v accessory leads hidden somewhere on a scrambler?
08 Sportsman 800 Touring- 2500lb Polaris winch, front & rear brush guards, front rack extender, headlight Mod, Quadovator temp gauge, RAC Engineering reverse/ work lights, Polaris rear storage box
05 Scrambler 500 (wife's bike)- Polaris rear rack, Bear Claw tires
08-06-2011, 03:56 PM
Its pretty easy to run new ones.....
What do you need to do?
08-06-2011, 04:07 PM
Member #6432
Going to put an electric temp gauge on it. Figure I could tap into a headlight wire for the light circuit, but need a switched 12v source for the gauge.
08-06-2011, 05:08 PM
That won't draw much, you shoud be OK tapping into the 12V accessory port.
08-07-2011, 02:36 AM
Member #6432
What accessory port ? I'm doing this on the wife's scrambler, and there isn't a port. I'm hoping there are a couple of wires under the hood I can use.
08-07-2011, 04:42 AM
My bad, sorry... Was just in my pod on the Sportsman and responded... You may need to run a new wire. Its a bit of a pain but is the best way to go. You just need a power wire, the neg or ground side is the frame. Be sure you fuse it.
12v plug on polaris 500 scrambler, aluminum rims for scrambler 500, atv 12v accessory, auxiliary wire polaris scrambler, how to wire a 12v winch, is there a 12v wire to tap for a light polaris sportsman, polaris 500 scrambler 12v?, polaris scrambler 12v, polaris scrambler 500 12v outlet, polaris winch accessory wire, where is accesory wire on polaris sportsman, wire winch to 12v plug, wiring a 12v atv horn
