Old 08-10-2011, 07:04 PM
trailboss4x4's Avatar
Member #1042
Sportsman 400 clutch spring?
Hi everyone, I just bought a 2005 sportsman 400. It has an epi clutch kit on it aparently, and has some parts in the box. This includes a white spring, orange spring, and blue spring, and stock helix and weights. It says the kit is for a sportsman 500 on the box, will this affect anything? I was pulling trees out for a neighbor the other day, and rather then spin the tires it smoked the belt, at like 5k rpm with absolutely no wheel movement. I can only assume the primary spring doesn't engage strong enough? I don't know much about clutches. I got the trees out with a sharp yank of course though. So I am wondering if one of the other springs would be a better choice for me to put in? The machine is not an 800 obviously, so I didn't buy it expecting top end and I don't mind losing some, if it means I can prevent smoking my clutch. I want something that hooks up better. I read that the orange spring should make a difference? Can anyone confirm this? Also, I believe the blue spring is supposed to be in the secondary as an upgrade also, would there be any reason why the past owner chose not to install it? Should I? Or should I buy heavier weights? Or maybe even just got back to stock? I know these are slot of questions, but I am hoping I can use what I have and get what I want out of it, and I just don't understand it well enough to do it myself. Thanks for any input!
Billy
2005 sportsman 400 4x4 Indy red
-Rad relocation
-EPI clutch kit
-EPI front arms
-12 inch Polaris alloys, 26 inch Carlisle Pxt's
-Front and rear bumpers
-3500lb Runva winch, synthetic cable
-Rear worklights
-Hand and thumb warmers
WISHLIST
-26inch Act xlr's
-Gorilla axles (maybe not, $$$!!!!)
-H.I.D. Lights
-Supertrapp mudslinger muffler, or AAEN Megaphone
-Graphic dipped bodywork, Snow Camo
1979 Yamaha Enticer 250
Terra jet
2003 Yamaha fjr1300-power commander (dads)
1997 Bmw 328i
2011 Dodge ram 1500 laramie (hunter green pearlcoat, dads)
[SIGPIC]
Old 08-11-2011, 06:49 PM
Member #1042
As an update, I found out the blue spring i had Is a primary and installed that tonight, gives me the exact pick up I wanted, and a little more top end then the red spring. Really happy with it. Tried the orange also, and it reved my machine way to much before there was any movement. I think I may go back to the red if I upgrade to a larger tire, but for now the blue is perfect!
-Rad relocation
-EPI clutch kit
-EPI front arms
-Rear worklights
WISHLIST
-26inch Act xlr's
-H.I.D. Lights
Terra jet
1997 Bmw 328i
[SIGPIC]
05 sportsman 400 blue primary clutch sping
05 sportsman 400 clutch kits
2003 sportsman 400 automatic clutch
2005 polaris sportsman clutch spring
clutch parts polaris sportsman 400
clutch spring for sportsman 400
clutch springs for sportsman 400 with 26
epi clutch kit polaris sportsman 400 ho
good clutch spring for sportsman 400
performance up grades for polaris 400 sportsman
polaris 400 sport orange spring
polaris 400 sportsman drivin clutch spring
polaris 400 sportsman secondary clutch spring
polaris atv white spring
polaris sportsman 400 clutch spring
polaris sportsman 400 performance mods
polaris sportsman red spring mod
polaris sportsman red spring upgrade
sportsman 400 clutch upgrade
sportsman 400 performance clutch
05 sportsman 400 clutch spring question... justin.boyea Polaris Sportsman 6 04-11-2012 10:04 PM
Clutch or Clutch spring upgrade help!!! eazytony27 Polaris Scrambler 3 04-11-2012 09:55 PM
Clutch spring ??? cwlongshot ATV Repair and Maintenance 6 04-11-2011 01:59 AM
Clutch spring for 600 lvanhorn ATV General Discussion 0 02-11-2011 11:32 AM
ideal clutch spring 425whpsti ATV Performance Modifications 2 12-16-2010 06:19 AM
