Old 08-15-2011, 06:10 PM
chad1926's Avatar
Member #11166
2011 sportsman xp epi clutch kit?
Anybody install one on their machine, I put one in mine and it decelerates really fast like it almost seems like the tires are sliding if im on gravel, is this normal or?
Old 08-15-2011, 07:35 PM
turbo590's Avatar
Member #12981
I just got done installing one in my 2009 XP850 EPS. Will be riding it for the first time this weekend, I'll let you know. Anxious to try it out finally.
Old 08-16-2011, 03:43 AM
Batman's Avatar
Member #9943
Send a message via AIM to Batman Send a message via Yahoo to Batman
I had this kit and was not a fan of it. I love my QSC Mud Pro kit.
- Sent from my iPhone using Tapatalk
2012 RZR XP White LE Stock.......for now
2009 Polaris 850XP with EPS 32" Backs on MSA Reapers, Rhino Front Axles, Pit Bull Growlers on ITP SS 212 Black, HL Springs, Warn XT30, QSC Clutch Kit and SLD Mod, Triangle ATV Stealth Snorkit, Backplate w/ Cooler, Backrest, SAW Ammo Cans, ODI Rogue Grips, ATV-Guru Rear Brush Bumper, HIDs, RDC Footpegs, Riochet Black A-Arm Guards & Tunes
2007 Green Honda Rincon, plenty of goodies, gone but never forgotten.
Old 08-16-2011, 06:03 AM
Cableguy657's Avatar
Member #3405
first off i only have 27 inch tires, XTR's.
mine is doing the same thing. i was riding at the rock run reuion tour this past weekend, the first time with the clutch kit. going down hill i was on the gas and the brakes at the same time so i didnt drag the rears down the hill.
the clutch engages better but also increases the way in grabs on deceleration.
when stopped on a hill, i was taking it easy when i took off and it seemed like i was up to 3000 rpms before i really got going.
i dont know if i have a problem or it is what it is.
my polaris dealer installed it, so it shouldnt be a problem with the install.
the kit did fine if i was hammering the bike to do hill climbs.
i may be taking mine out unless i can maybe change the engagement rpm. when i get a chance i am going to call epi to see if i can do something with it.
this maybe another one of the should have left well enough alone times!
I am not sure what i am going to do with it.
2011 850 XP EPS
Browning LE
27" XTR's
Atv Guru Cobra series brush guards
Warn XT30
F/R L&R Boxes
G3 60" plow
2012 RZR
Polaris Pursuit camo
Atv Guru Bumpers
Warn XT30
26" Grim Reapers
ss108
Racer Tech 2inch lift
Makin Trax springs
Old enough to know better but, still too young to care!
http://s859.photobucket.com/home/cableguy657/allalbums
Old 08-16-2011, 09:51 AM
turbo590's Avatar
Member #12981
QUOTE: I may be taking mine out unless i can maybe change the engagement rpm. when i get a chance i am going to call epi to see if i can do something with it.
I am not sure what i am going to do with it.[/QUOTE]
Just riding mine around the yard...I did email EPI...the response I received back....
I received your email on the 850 xp. The bad news is with that machine it is really hard to ever fix that problem. The kit I thought help a little but did not completely fix the problem. You can try heavier weights usually that makes the machine sluggish and you lose response. It also seems that the lower the engagement the rougher the machine comes on at low speeds. So my only thought is I could recommend you to a lower engagement spring but it may not help completely and you do lose some of the low end punch. Please get back to me on what your thinking and if you want to try one of the two things I have mentioned.
2009 Sportsman 850 XP EPS LE-Tequila Gold
Sedona Storm 14" aluminum ATV wheels
Pitbull Growler UBER II XOR 8-ply Tires
27.5x9R14 (front) * 27.5x11R14 (rear)
Hot Seat Performance slip on exhaust (2009)
Highlifter 3" Signature series lift kit
EPI performance clutch upgrade, EPI replacement belt
Polaris Deluxe Front/Rear brush guards...replacing the extreme bumper set
NGK plugs
UNI Airfilter NU8503ST
WARN XT30 winch (synthetic rope) wireless, KFI Hawse aluminum fairlead
Polaris OEM Hand warmer kit
Polaris Billet Shifter and fuel cap.
EBC Brakes (Front and Rear)
PIAAź lights
Polaris OEM Hand Guards
Old 08-16-2011, 11:22 AM
Member #3405
so it seems the two solutions are....... to get used to the way it is or go back to stock and never to do another clutch kit.
2011 850 XP EPS
Browning LE
27" XTR's
Warn XT30
F/R L&R Boxes
G3 60" plow
2012 RZR
Atv Guru Bumpers
Warn XT30
26" Grim Reapers
ss108
Makin Trax springs
Old 08-16-2011, 12:56 PM
turbo590's Avatar
Member #12981
My issue was...having a "heavier" set of tires/wheels other than the factory issued (combo). While riding, roughly into 10 miles...the heat from the factory belt/clutch was transferring up through my seat...making the ride very uncomfortable...the "upgrade" should take care of this...I will find out the upcoming weekend....long ride.
Anything over stock tires/wheels...should get a clutch upgrade, especially if the tire/wheel combo(s) have considerable "extra" weight tied to them...we will see....great topic
Kurt
NGK plugs
PIAAź lights
Old 08-16-2011, 01:40 PM
Member #3405
the clutch kit for the 2011's came without a new helix, so i guess EPI felt that the one from the Polaris was good as it must have changed in 2011. this kit was about $100 less than the one for the 2010's and 09's. i dont know how much of a difference this would make on the operation of the different models
when i first rode it around the yard it seemed that the engagment was only about 400 rpms more but when i had it on a hill it seemed to be twice that.
i too have oversize tires but they are not as heavy or as talll as yours. again i guess i should have left it alone.
i have another ride planned in a few weeks, i will give it another shot as this past weekend i really didnt ride it much as normal, i think i only did 30 miles.
2011 850 XP EPS
Browning LE
27" XTR's
Warn XT30
F/R L&R Boxes
G3 60" plow
2012 RZR
Atv Guru Bumpers
Warn XT30
26" Grim Reapers
ss108
Makin Trax springs
Old 08-16-2011, 02:27 PM
skizmo's Avatar
Member #13773
"Anything over stock tires/wheels...should get a clutch upgrade, especially if the tire/wheel combo(s) have considerable "extra" weight tied to them...we will see....great topic" QUOTE
I dont know about that,because I put 27" swamp lights (6 ply) on my 550 and the bigger/heavier tires smoothed the delayed engagement out big time....I lost NO power at all....and I feel that I hooks up quicker with these tires...when I first got the bike I thought something was wrong with the "delayed engagement"...clunk when you hit the throttle,the dealer told me Polaris made the clutch expecting the buyer to put bigger tires on the bike...and not to worry..i put bigger tires on and the clunk went away....
with that being said.my buddy put 28" swamp lights on his 850 and he says he lost considerable bottom end and the clunk got worse..the dealer told him he needed a clutch kit..to recover his bottom end power...and smooth the engagement out
Im know expert this is just what has happened to us....
Get Some!
2011 Sportsman 550 XP Camo
ATV Logic Rear Storage Pack
Fin Grip Gun And Bow Holder
Custom 2-Up Seat
Pure Polaris Hand Guards
27' Swamp Lights
Polaris Front Lock&Ride Box
Ricochet A-Arm Guards (Black)
ATV Superstore 3 way Hitch
Garmin GPSmap 62
Old 08-16-2011, 04:21 PM
SNW629's Avatar
Member #1414
you should not be dragging the rear tires,the back shift is off,piss poor clutch kit design. i would take out the hunk of crap and get my money back. best thing to do with the 850xp with stock or close to stock size tires is to stay with the stock clutch,unless you really know clutching and how to tune one with a good design kit.
09 850XP EPS
RT30 WARN WITH KFI MOUNT
2011 polaris atv sportsman 850 xp clutch kits
2011 polaris sportsman 850 xp qsc speed pro clutch kit
2011 polaris sportsman 850xp epi clutch kit not installing secondary
2011 sportsman 850 xp clutch kit
2012 polaris 850 xp 3 inch lift
8 inch lift kits for 2011 polaris 850xp
850xp with epi clutch
best clutch kit for polaris 850xp
clutch kit 2011 polaris 850xp
clutch weights for polaris xp to run 30'' tires
epi clutch kit 2011 polaris 850 xp
epi clutch kit for 850 xp
epi clutch kit for sportsman 850 2011
epi clutch kit polaris xp reviews
epi clutch performance polaris
installing clutch kits sportsman xp
polaris 2012 850 sportsman epi clutch kits
polaris 850 clutch kit recommendations
qsc 2011 polaris sportsman 50 clutch kit
sportsman xp clutch kit
2011 Sportman 400 or 2011 Kingquad 400fsi 2000xplorer250 ATV Purchasing and Price 19 08-15-2011 05:18 AM
having clutch problems wonder if its due to big tires or clutch wear HELP johnnypolaris500ho ATV Wheels & Tires 8 04-03-2011 07:17 PM
Rebates on Nearly all 2010 and 2011 Models March 1st, 2011 cmharcou ATV Purchasing and Price 0 03-02-2011 02:56 AM
Sportsman 700 Clutch Kit Super ATV Polaris Sportsman 2 08-23-2010 03:51 AM
Primary clutch squeak after installing clutch kit x omerta x Polaris Sportsman 20 08-10-2010 01:46 PM
