Old 08-21-2011, 11:56 AM
SpartanTX117's Avatar
Member #3503
Sportsman clutch question
I have a 2003 Sportsman 700. I just got a primary clutch from a 09 Sportsman 800 given to me and am in the process of switching it out and was wondering if i would have to switch out the secondary as well? I have read so differing opinions on this. Thanks!
Old 08-21-2011, 03:39 PM
mstermechanic907's Avatar
Member #17047
Send a message via MSN to mstermechanic907
no you can run the stock 700 driven clutch also run the 800 clutch spring and 800 clutch weights and drive belt.
Old 10-31-2011, 04:34 PM
jeffhornby's Avatar
Member #20084
I have a 2002 with a good primary clutch but need a new secondary .
does this been that a secondary off a 2008 will work with a 2002 primary too??
Old 11-01-2011, 12:37 PM
the 03 stock secondary will work but you will be happier with the newer ,Roller secondary, I did ths to my 03-700, adds quite a bit more bottom end, may lose a little top but the newer clutches grab the belt alot better, didnt use low range near as much, also get the 800 belt, alot tougher
Old 11-01-2011, 12:38 PM
yes the 08 secondary will work with the older primry but t6hey work better if both are newer
Old 11-01-2011, 04:19 PM
jeffhornby's Avatar
Member #20084
Thanks for the reply
is there a belt you can recommend
should I go with the stock belt for the 02 or use the stock belt from the 08
let the experimenting begin!!
Old 11-02-2011, 01:56 AM
cwlongshot's Avatar
Exclamation
STOCK 800 belt all the way!
sportsman clutch
05 sportsman 400 clutch spring question... justin.boyea Polaris Sportsman 6 04-11-2012 10:04 PM
EPI clutch question G0merP ATV Performance Modifications 1 08-09-2011 09:01 AM
Clutch Question 04Predator4408 Polaris Predator 0 11-19-2010 06:51 PM
Clutch Question SpartanTX117 ATV Repair and Maintenance 3 03-10-2010 06:43 PM
500 H.O. Carb Clutch question 91bird ATV Performance Modifications 1 02-16-2010 03:54 AM
