Old 08-21-2011, 03:31 PM
muddin's Avatar
Member #17882
front end engaging by its self
I have a 2011 sportsman 800 and the front end will lock by its self will its in 2wd anyone have any suggestions what to look for.
Old 08-21-2011, 03:56 PM
mstermechanic907's Avatar
Member #17047
Send a message via MSN to mstermechanic907
i would check the 4x4 switch,try unplugging the switch on the thumb throttle block,if the 4x4 stays off than i would replace the 4x4 switch,it only comes mounted on the throttle block as an assy.
Old 08-21-2011, 04:02 PM
muddin's Avatar
Member #17882
Thanks I will try that. I unplugged it at the diff and it still acted up.
Old 08-21-2011, 05:23 PM
polaris50007's Avatar
Member #13981
Angry Thick fluid
Mike here,service the diff,if the fluid is too thick from not servicing it will cause this problem,Mike
Old 08-21-2011, 05:57 PM
muddin's Avatar
Member #17882
Thanks I will change it out , I did check it and it looked a little black in color. But the bike only has app. 60 miles on it. What can I clean the inside with that won't hurt anything.
Old 08-22-2011, 06:21 AM
Member #13981
Angry Dirty?
muddin,Mike here.I see you only have (3) posts.Everyone welcomes you I'm sure.I was having a problem with mine not disengaging all the time.It was due for a service.I talked to a dealer mechanic and he said I could use Dexron 6 trans fluid to clean it out.He said you could also continue to use is for the oil.I decided to go back with the recomended fluide because thats what is called for.The dexron rinsed it out fine,replenished the fluide and every thing is A.O.K. now.Mikght want to give it a try,MIke
Old 08-22-2011, 07:15 AM
lost cause's Avatar
Member #9763
First check and make sure the fluid is good in the diff. Make sure it is polaris brand. If that's not the issue than you may have cracked/broken the sprague cage in the front diff.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
AWD engaging while off. HELP! xfactor Polaris Sportsman 6 06-15-2011 03:05 PM
2002 500 sportsman both front axle not engaging davidc1203 Polaris Sportsman 4 05-24-2011 06:01 AM
new to site.xplorer 400 4x4,front hubs engaging without using switch randygpolaris ATV New Members 4 02-24-2011 07:04 PM
05 Sportsman 700 4x4 not engaging front wheels larme58 ATV Repair and Maintenance 3 02-07-2011 11:27 AM
02 Sportsman 500HO - AWD front hub not engaging hilliard clutch lock armature plate cookies ATV Repair and Maintenance 9 12-09-2010 06:48 AM
