Old 09-01-2011, 08:13 AM
polaris50007's Avatar
Member #13981
Unhappy Power commander???
Mike here.Does anyone out there know where I might purchase a power commander or other fuel programmer for my 2007 Sportsman 500 EFI.I am installing a hot seat exhaust and still want a programmer.Any help is greatly appreciated,Mike
Old 09-01-2011, 09:48 AM
cwlongshot's Avatar
Have you looked at your pipes manufacturer? Most times they have a recomended controller...
Old 09-01-2011, 01:24 PM
racer37l's Avatar
Member #5629
Hot Seat sells the PC III for your bike.
Con
Old 09-01-2011, 01:28 PM
Member #13981
Question No suggestions??
CW,Mike here.Thanks for responding.I purchased it from Speedwerx,Inc.They had no suggestions at the time I purchased it.Now I've gone to their web site and can not find a programmer for my 07 500 EFI.Any other suggestions from you at this time?Mike
Old 09-01-2011, 01:32 PM
Member #13981
Thanks racer371 for the info.I'll try them out and get with all.Mike
Old 09-01-2011, 02:17 PM
racer37l's Avatar
Member #5629
Speedwerx and Hot Seat Performance are one in the same!
After some more research, I can't find that Dynojet makes a programmer.
Going to look at HMF!
Update: You may be in luck with HMF. They make one for 500-800 X2 EFI. I'd give them a call.
You may try to Google this also.
Con
Old 09-02-2011, 05:23 AM
Member #13981
Question $$$???
Hey guys,Mike here.Thanks for all the input on the programmer idea.I found several but the prices of $300-400.00 isn't worth the 2-3hp.I tore down my other sportsman 500 in the past and bored it-milled the head-shaved the jug 0.20 over and gained 7.2 hp on the dyno for less money.Thanks anyway,Mike
800 polaris power commander
how much power does a power cammander give a polaris sportsman 500
how much power does a power commander give you polaris
polaris 800 efi power commander forum
polaris sportsman 500 efi power commander
power commander for 2007 polaris sportsman 800
power commander for 500 polaris sportsman
power commander for 500 sportsman
power commander for polaris sportsman 2011
power commander for2007 sportsman 500
powercomander for sportsman 500
sportsman 500 power commander
how much power does a power commander give a 850 xp 4x4addict ATV Performance Modifications 2 08-01-2011 09:02 AM
power commander Raimey ATV Performance Modifications 2 07-07-2011 06:05 PM
Power commander v 850xp gaspumpcity ATV General Discussion 1 10-14-2010 07:18 PM
what power commander should i get ???? lsxmike ATV Performance Modifications 8 07-15-2010 05:53 PM
preloaders and EFI commander eatmydust ATV Performance Modifications 1 05-24-2010 06:56 PM
