Old 09-04-2011, 03:38 PM
utgreenhead's Avatar
Member #13968
Power Commander V 19-005 vs 19-014
The 19-005 is available and the 19-014 says "coming soon".
Does anyone know what the difference in the two is?
UTG
2011 Polaris Sportsman 850 XP EPS Black
ATV-Guru Cobra Series Front & Rear Bumpers
The ATV Superstore 3 in 1 Hitch
The ATV Superstore 3 light HID Kit
WARN XT30 Wireless Winch
Ricochet Ultimate Armor Skid Plate Kit
Hatchie Bottoms Neoprene Camo Seat Cover
ITP SS212 Blacks w/ GBC Spartacus' 27" @ 5 psi
Speedwerx "Hot Seat" Slip-on Exhaust
Hypershift Clutch Kit
Future Items:
Power Commander V
Old 09-09-2011, 09:49 AM
DynojetResearch's Avatar
Member #18502
19-005 has fuel control only. 19-014 gives you fuel AND ignition control all in the same box. You can adjust timing up to +/- 20 degrees. It will also allow you to increase the rev limiter if desired. These units are currently in stock. Website will be updated this week.
19-014 power
19-014 power commander
dynojet 19-014
pcv 19-014
power comander 19-014
power commander 19-014
power commander ignition xp 850 -4 degrees
power commander v 19-005
power commander v 19-014
power commander v sportsman 850
power commnader v 850xp timing
powercommander part number: 19-014
Power commander??? polaris50007 ATV Performance Modifications 6 09-02-2011 05:23 AM
how much power does a power commander give a 850 xp 4x4addict ATV Performance Modifications 2 08-01-2011 09:02 AM
power commander Raimey ATV Performance Modifications 2 07-07-2011 06:05 PM
Power commander v 850xp gaspumpcity ATV General Discussion 1 10-14-2010 07:18 PM
what power commander should i get ???? lsxmike ATV Performance Modifications 8 07-15-2010 05:53 PM
