Old 09-10-2011, 03:50 AM
jt500x02's Avatar
Member #18490
carb tuning jets needles floats bowls etc.
ok quad is a
02 scrambler 2wd, 500x model which is assume is H.O.
i have a wiseco piston 10.1 which the cylinder walls were bored out to what equalled 510cc i think
WEB RACING CAM - Valve lift .335/.335, Duration 256/256 Degrees, Duration @ 0.050 230/230 degrees. Grind # 653.
AAEN TMX 42mm Flatside Carb.
Hpd airbox mass airflow intake with K&N Air filter
Hpd exhaust
i need to get some info on the proper jetting neddle positon???, bowels, floats, etc.
please and thanks for the help
More throttle, Less Fear!
2000 tmx carb float setting
adjusting a mikuni carburetor on a polaris 425
adjustment of polaris carbs
atv performance needles and needle jets
carb needle on polaris
diagram of a mukuni carburator on a polaris 335
float setting on mikuni carby for polaris
mikuni atv carb needle setting
mikuni carb needle adjustment polaris atv
polaris 335 bored out
polaris 425 carburator tune
polaris atv carburetor adjustment
polaris carb adjustment
polaris carb jets
polaris carb settings
polaris carb tuning
polaris carburetor adjustment
polaris etc
polaris magnum 425 4x4 carb settings
polaris needle setting
Need quick assistance with a starting point on tuning my sons carb RKMHD ATV Performance Modifications 0 08-20-2011 04:25 AM
tuning 800touring Polaris XP 4 08-17-2011 12:04 PM
tuning a scrambler 400..... dgsmooth ATV Performance Modifications 2 04-05-2011 05:11 AM
New K&N Filter - Need Jets Now., 1995 Polaris Magnum 424 4X4 Mikuni Carb Magnum425er ATV Performance Modifications 2 02-28-2011 09:35 AM
Carb Jets ssheehan ATV Repair and Maintenance 2 01-24-2011 05:02 PM
