Old 09-25-2011, 12:16 PM
redrider022002's Avatar
Member #18580
air filter question
all of my bikes are stock but i am looking at putting high performance air filters on the as i have had some problems with them at high altitudes. they run fine with the airbox cover off but are quite loud. my question is which is better the uni filter or k&n?
2000 scrambler 400 2 stroke 2wd (stock)
2006 scrambler 500 4wd (stock)
2007 scrambler 500 4wd (stock)
2012 scrambler 500 4wd (stock)
Old 09-25-2011, 12:41 PM
cwlongshot's Avatar
UNI
K&N is not worth the effort!!
Old 09-25-2011, 12:47 PM
KICKER431's Avatar
Member #18006
just got my Uni's for my 2 based on Longshot's recommendation. Putting them in tomorrow. I can get back to you if you want but Uni seems to be the consensus around here so that is why I got mine.
2004.5 Sportsman 700 EFI
2007 Sportsman 700 EFI
Old 09-25-2011, 01:40 PM
bltjpt's Avatar
Member #9383
Uni Filter
Just got back from Colorado and was riding in the mountains at 13000 feetand had no problem with the Uni filter. Just keep it clean.
Old 09-25-2011, 02:12 PM
jordaman17's Avatar
Member #13240
uni for sure.
Old 09-25-2011, 02:18 PM
Member #18580
well i guess ill get some uni filters. are they cotton and oil like the k&n filters?
Old 09-25-2011, 02:28 PM
SMP63's Avatar
Member #13545
Mine are a foam precleaner & foam filter, i use the UNI oil on them & the UNI
cleaner to clean them.
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 09-25-2011, 02:33 PM
cwlongshot's Avatar
Wink
Like SMP63 said, they are foam with a foam cover. Both get oiled.
Old 09-25-2011, 03:09 PM
Member #18580
cool. thanks for the info
Old 09-27-2011, 02:51 PM
Diesel man 03's Avatar
Member #7294
I put the UNI on my 500HO.
powered by vbulletin high performance air filter
scrambler 500 uni filter
uni air filter scrambler 500
Uni Filter Question scum_frog ATV General Discussion 12 06-26-2011 04:59 PM
Oil filter selection question mike240 ATV Repair and Maintenance 3 03-22-2011 10:28 AM
Oil Filter question socal Polaris Predator 1 01-01-2011 12:12 PM
Oil Filter Question.... Gatorbait2001 Polaris Sportsman 9 09-01-2010 12:18 PM
newb with air filter question vitosdraggin ATV New Members 3 08-19-2010 02:44 AM
