Old 10-01-2011, 10:08 AM
coryv4's Avatar
Member #19179
96 sportsman 500 turbo
Hi i am new to this forum and i wanted to get some opinions i have a turbo that came off my yfz(rod through case)and i have it set up for 12lbs of boost. would my 500 handle roufly 5-7lbs of boost i can turn the waiste gate down soo it blows off at about 5lbs? i was thinking a draw trough setup turbo direct to motor with carb on sucking side of turbo?
Old 10-02-2011, 06:26 AM
Old 03-07-2012, 07:57 PM
Rubicon's Avatar
Member #23904
Ah ha
A man after my own heart.
I have lots of experience with turbos and old cars so lets settle in.
Cfm is your main concern here. If you draw in the mixture of fuel into the hair dryer you will tarnish your rotor and cause bearing issues. Since running efi is not possible I would blow air into your carbs but at 5 psi you will want to increase your jet size to 5 times the current size which might not be possible with that current carb.
5 psi is 5 times more barrimetric pressure than sea level hence the five times more fuel needed to keep it acceptable.
Old 03-13-2012, 07:07 AM
coryv4's Avatar
Member #19179
Originally Posted by Rubicon View Post
Ah ha
i have a little experience with turbos also but my other concern with a blown carb would be is the stock fuel pump going to overcome to the boost? i have yamaha banshee 421 cub running 15lbs of boost on alcohol and i need to have a constant +4 fuel pressure as is 4lbs at idle and 19lbs at 15lbs of boost and so on.the turbo that is on the banshe is a decent size its a garrett m24 with a .80 compressor. the one i want to use on the polaris is a ihi vf14 wich is a small secondary turbo it doesnt matter how much boost i run weather it is 1lb or 20 i just want to see if i can get a little gain out of the motor with what i have at hand.
Old 03-13-2012, 10:25 AM
Rubicon's Avatar
Member #23904
As odd as it sounds you may have to run an aux pumper connected to a relay which is triggered by a WOT switch. You are delving in the relm of experimental so building a fuel pressure regulator would help with controlling your now boosted aux fuel pumper.
Old 03-14-2012, 04:36 AM
coryv4's Avatar
Member #19179
by any chance would you know how much preassure the stock pump puts out maybe i could run 2-3 lbs with out working against the pump?
Old 03-14-2012, 06:33 AM
Rubicon's Avatar
Member #23904
I do not know the current fuel delivery pressure. I would not be surprised if it were gravity fed.
2008 polaris sportsman 500 turbo charger kits
500 polaris sportsman turbo
96 sportsman 500 performance
96 sportsman mods
adding boost to polaris sportsman
modifications for carburetor on turbo atv
polaris 500 turbo kits
polaris atv turbo
polaris sportsman 500 turbo buy
polaris sportsman 500 turbo kit
polaris sportsman 500 with a turbo
turbo atv carb draw through
turbo atv carb suck through
turbo kit for sportsman 500
turbo kits for polaris sportsman
turbo polaris 500
turbo sportsman 500
turbocharged atv
turbocharged atv drawthrough
2008 sportsman 800 ho turbo adam5187 ATV Performance Modifications 0 04-06-2011 11:44 AM
Any turbo or supercharger kits yet? archer Polaris Sportsman 4 12-16-2010 08:03 PM
Adding Turbo to a 2 stroke Boostedawd91 ATV Performance Modifications 5 06-11-2009 05:33 PM
